Poly Blackwire 5210 C5210 USB-C Headset
Quicklinx: HM5CWS00 Mfr#: 805H4AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
Earcover : Monaural
£60.07 ex VAT
£72.08 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
  • Connectivity options
    Select the right option for your device: USB-A or USB Type-C for PC and 3.5 mm for mobile connectivity.
  • Comfort and durability
    Ultra-soft leatherette ear cushion(s) wrapped around pillow-soft memory foam provide long lasting comfort. A lightweight cushioned metal headband offers durability and a comfortable custom fit.
  • Wearing style
    Monaural wearing style for those who prefer to leave one ear open.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Audio quality
    Premium PC wideband audio with noise-canceling microphone and Digital Signal Processing (DSP) for a more natural voice sound.
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
Poly Blackwire C5210 - headset
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
Software Certification
Certified for Skype for Business, Certified for Microsoft Teams, Avaya Certified, Cisco Jabber Certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
Earpad Material
Artificial leather
Recommended Use
Audio Output
On-ear monaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
118 dB
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Digital signal processing, Dynamic EQ optimised
Microphone
Boom
Omni-directional
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Supported Host Device OS
macOS, Windows
HM5C Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.42
HM5C Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £24.71
HM5C Poly Audio Cable - M22 to Quick Disconnect for Poly EncorePro In Stock £10.99
HM5C Poly DA75 Sound Card In Stock £32.13
HM5C Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.64
HM5C Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.82
HM5C Poly HIS Adapter Cable In Stock £24.71
Recommended Use: Portable electronics
Connectivity: Wired
Earcover : Monaural
Brand: Poly
