Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C
Quicklinx: JBV2WS00 Mfr#: 8X230A6
26 In Stock
£53.80 ex VAT
£64.56 inc VAT
The Blackwire 5200 Series fits your busy workday. Ergonomically designed for long lasting comfort. And with the easy-to-use connectivity you can work on a variety of devices throughout the day.
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Mono
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end
Software Certification
Certified for Microsoft Teams, Certified for Skype for Business, Cisco Jabber Certified, Avaya Certified, Works With Chromebook Certified, Zoom Certified, UC certified
Series
Blackwire 5200 series
Compatibility
Mac, Windows
Earpad Material
Artificial leather
280° rotatable microphone
Audio Output
On-ear monaural
Wired
Sound Output Mode
Mono
118 dB
Sensitivity
116 dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised, echo reduction
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
Carrying case, USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
JBV2 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.14
JBV2 Poly - USB adapter - USB to 24 pin USB-C In Stock £13.35
JBV2 Poly - USB adapter - 24 pin USB-C to USB In Stock £13.00
Brand: Poly
