Poly Blackwire 3325 BW3325 USB-C
Quicklinx: G1C4WS00 Mfr#: 213939-01
The great appeal of the Blackwire 3300 is apparent at first sight: It has a sleek, modern design. Workers want to wear it-so your investment pays off. Not only that, it sounds as good as it looks, with high-quality audio you've come to expect from Poly.
  • Connect quickly and easily
    The Blackwire 3300 Series is completely plug-n-play with USB devices, so you can take calls in-the-office or on-the-go. Its robust design delivers reliability you can count on. This is the hassle-free headset you're been looking for.
  • Look good, feel good, sound amazing
    The sleek, modern design looks as good as it sounds. Crisp audio paired with all-day comfort lets you handle any call with ease.
  • Made to make the most of meetings
    All Poly USB headsets and personal speakerphones are compatible with the most popular collaboration platforms - they just work. Expect to hear and speak with the level of audio quality that Poly is famous for, no matter which platform you're calling on.
Poly Blackwire 3325 - headset
Headset - wired - 3.5 mm jack, USB-C
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Noise Cancelling
Controls
Mute, volume, answer/end
Series
3300 Series
130 g
Earpad Material
Leatherette
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
94 dB
Impedance
32 Ohm
Diaphragm
32 mm
In-Cord Volume Control
Adjustable Headband
SoundGuard Technology
Microphone
Boom
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headset (mini-phone 3.5mm)
Carrying pouch
Cable Details
Headset cable
