Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Connectivity options
Enhanced connectivity for your devices: USB Type-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity. -
Microsoft Teams
Microsoft Teams version to support an easy collaboration and communication with a dedicated Teams button for instant access to the Teams App.
- Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C
- Product Type
- Headset - wired - 3.5 mm jack, USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 Ohm
- Signal-To-Noise Ratio
- 118 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Microsoft Teams, UC certified
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 131 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- 135° rotatable microphone, 280° rotatable microphone
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 118 dB
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Dynamic EQ optimised
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C) , Headset (mini-phone 3.5mm)
- Software Included
- Poly Lens
- Included Accessories
- USB-C to USB-A adapter, travel case
- Supported Host Device OS
- Windows 10, macOS
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
