Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Connectivity options
Enhanced connectivity for your devices: USB Type-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C
- Product Type
- Headset - wired - 3.5 mm jack, USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Answer/end, mute, volume
- Software Certification
- UC certified
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 131 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Adjustable Headband
- Dynamic EQ optimised
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dB
- Frequency Response
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C) , Headset (mini-phone 3.5mm)
- Included Accessories
- USB-C to USB-A adapter
- Supported Host Device OS
- Windows 10, macOS
- UC certified
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £12.98 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
Poly Spare Foam Ear Cushion BW3310 BW3320 | In Stock | £2.66 |
