Poly Blackwire 3320 headset - on-ear - wired - USB-C - black
Quicklinx: HNH0WS00 Mfr#: 76J18AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
£34.49 ex VAT
£41.38 inc VAT
Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
  • High-quality audio
    Makes collaboration easy with Poly signature audio quality and reliability.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Flexible microphone boom
    With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom.
  • Long-lasting comfort
    Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions.
  • Connectivity
    Select the right option for your device: USB-A or USB Type-C ? for PC and 3.5 mm for mobile connectivity with select models.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
HP Poly Blackwire 3320 - headset - USB-C
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 116 dB
Impedance
32 ohm
Microphone
Boom
Controls
Answer/end, mute, volume
Series
Blackwire 3300 series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
17.8 cm
130 g
Earpad Material
Foam
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
116 dB
Impedance
32 ohm
Max Sound Pressure
118 dB
Diaphragm
32 mm
In-Cord Volume Control
Adjustable Headband
Dynamic EQ optimised
Microphone
Boom
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
Supported Host Device OS
Windows 10, macOS
Shipping Width
18.5 cm
Shipping Depth
5.6 cm
Shipping Height
20.7 cm
Shipping Weight
255 g
HNH0 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.14
HNH0 Poly Headset Splitter - Y-type training cable for Poly EncorePro In Stock £25.58
HNH0 Poly DA75 Sound Card In Stock £27.38
HNH0 Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.78
HNH0 Poly HIS Adapter Cable In Stock £25.58
HNH0 Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HNH0 Poly - USB adapter - 24 pin USB-C to USB In Stock £13.00
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
