Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Select the right option for your device: USB-A or USB Type-C ? for PC and 3.5 mm for mobile connectivity with select models. -
Microsoft Teams
Microsoft Teams version to support an easy collaboration and communication with a dedicated Teams button for instant access to the Teams App.
- Poly Blackwire 3320-M - headset - USB-C
- Product Type
- Headset - wired - USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 116 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 130 g
- Black
- Earpad Material
- Foam
- Recommended Use
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Adjustable Headband
- Dynamic EQ optimised
Microphone
- Boom
- Sensitivity
- -38 dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
- Supported Host Device OS
- Windows 10, macOS
- Shipping Width
- 18.5 cm
- Shipping Depth
- 5.6 cm
- Shipping Height
- 20.7 cm
- Shipping Weight
- 255 g
Poly Headset Splitter - Y-type training cable for Poly EncorePro | In Stock | £25.08 |
Poly Headset Cable - M22 to Quick Disconnect for Poly M22 | In Stock | £10.80 |
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.69 |
Poly HIS Adapter Cable | In Stock | £15.68 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.85 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.11 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
