Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing Style
Monaural wearing style for those who prefer to leave one ear open. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Select the right option for your device: USB-A or USB Type-C ? for PC and 3.5 mm for mobile connectivity with select models. -
Microsoft Teams
Microsoft Teams version to support an easy collaboration and communication with a dedicated Teams button for instant access to the Teams App.
- Poly Blackwire 3315-M - headset - 3.5 mm jack, USB-A
- Product Type
- Headset - wired - 3.5 mm jack, USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 80 - 20000 Hz - Sensitivity 116 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 102 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
Audio Output
- On-ear monaural
- Wired
- Sound Output Mode
- Mono
- 80 - 20000 Hz
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 14.2 mm
- In-Cord Volume Control
- Adjustable Headband
- Dynamic EQ optimised
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dB
- 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone 3.5mm)
- Supported Host Device OS
- Windows 10, macOS
- Shipping Width
- 18.5 cm
- Shipping Depth
- 5.6 cm
- Shipping Height
- 20.7 cm
- Shipping Weight
- 224 g
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.71 |
Poly HIS Adapter Cable | In Stock | £24.75 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £13.36 |
