Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified
Quicklinx: HSMJWS00 Mfr#: 8X217AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
43 In Stock
£43.63 ex VAT
£52.35 inc VAT
Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
  • High-quality audio
    Makes collaboration easy with Poly signature audio quality and reliability.
  • Wearing style
    Monaural wearing style for those who prefer to leave one ear open.
  • Headset flexibility
    With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom.
  • Long-lasting comfort
    Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions.
  • Connectivity options
    Enhanced connectivity for your devices: USB Type-C cord with tethered USB-A adapter for PC and 3.5 mm for mobile or tablet connectivity.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Blackwire 3315 - headset - 3.5 mm jack, USB-C
Headset - wired - 3.5 mm jack, USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear monaural
Wired
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Answer/end, mute, volume
Software Certification
UC certified
Series
Blackwire 3300 series
Compatibility
Mac, Windows
103 g
Earpad Material
Artificial leather
Recommended Use
280° rotatable microphone, boom mic length 135mm
Audio Output
On-ear monaural
Wired
118 dB
Sensitivity
116 dB
Impedance
32 Ohm
Max Sound Pressure
118 dB
Diaphragm
14.2 mm
In-Cord Volume Control
Dynamic EQ optimised, echo reduction
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
UC certified
HSMJ Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.64
HSMJ Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HSMJ Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
HSMJ Poly Spare Foam Ear Cushion BW3310 BW3320 In Stock £2.62
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
