Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing Style
Monaural wearing style for those who prefer to leave one ear open. -
Headset flexibility
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Connectivity options
Enhanced connectivity for your devices with a USB Type-C cord and tethered USB-A adapter. -
Microsoft Teams
Microsoft Teams version to support an easy collaboration and communication with a dedicated Teams button for instant access to the Teams App.
- HP Poly Blackwire 3310 - headset - USB-A
- Product Type
- Headset - wired - USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 ohm
- Signal-To-Noise Ratio
- 118 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Microsoft Teams, UC certified
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 103 g
- Black
- Earpad Material
- Foam
- Recommended Use
- Boom mic length 135mm, 280° rotatable microphone, voice alerts
Audio Output
- On-ear monaural
- Wired
- 118 dB
- Sensitivity
- 116 dB
- Impedance
- 32 ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Dynamic EQ optimised
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
- Software Included
- Poly Lens
- Included Accessories
- USB-C cable, USB-C to USB-A adapter
- Cable Details
- USB-C cable
- Supported Host Device OS
- Windows 10, macOS
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black
