The great appeal of the Blackwire 3300 is apparent at first sight: It has a sleek, modern design. Workers want to wear it-so your investment pays off. Not only that, it sounds as good as it looks, with high-quality audio you've come to expect from Poly.
Connect quickly and easily
The Blackwire 3300 Series is completely plug-n-play with USB devices, so you can take calls in-the-office or on-the-go. Its robust design delivers reliability you can count on. This is the hassle-free headset you're been looking for. -
Look good, feel good, sound amazing
The sleek, modern design looks as good as it sounds. Crisp audio paired with all-day comfort lets you handle any call with ease. -
Made to make the most of meetings
All Poly USB headsets and personal speakerphones are compatible with the most popular collaboration platforms - they just work. Expect to hear and speak with the level of audio quality that Poly is famous for, no matter which platform you're calling on.
- Poly Blackwire 3310 - headset - USB-C
- Product Type
- Headset - wired - USB-C
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end
- Environmental Standards
- TCO Certified Headsets 9
- 2-year warranty
- Product Type
- Series
- 3300 Series
- 102 g
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 94 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Adjustable Headband
- SoundGuard Technology
Microphone
- Boom
- Sensitivity
- -38 dB
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
- Cable Details
- Headset cable
Sustainability Information
- TCO Certified
- Limited warranty - 2 years
