Poly Blackwire 3220 Stereo USB-A Headset
Quicklinx: HLJTWS00 Mfr#: 80S02A6
Recommended Use: Portable electronics, Computer
Connectivity: Wired
Earcover : Monaural
£24.44 ex VAT
£29.32 inc VAT
The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
  • Connectivity options
    Select the right option for your PC: USB-A or USB Type-C models.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Lightweight design
    A lightweight metal headband offers durability and a comfortable custom fit.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Blackwire 3220 - headset - USB-A
Headset - wired - USB-A
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Omni-directional
Controls
Mute, volume, answer/end, hold, redial
Software Certification
Skype Certified, Cisco Jabber Certified, Avaya Certified
Series
3200 Series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
17.8 cm
64 g
Earpad Material
Foam
Recommended Use
Packaging Type
Poly bag
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Adjustable Headband
Dynamic EQ optimised, echo cancelation
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Cable Details
USB-A cable
Supported Host Device OS
Windows 11, Windows 10, macOS
Shipping Width
18.5 cm
Shipping Depth
5.6 cm
Shipping Height
20.7 cm
Shipping Weight
250 g
HLJT Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.19
HLJT Poly Headset Cable - M22 to Quick Disconnect for Poly M22 In Stock £10.68
HLJT Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.72
HLJT Poly HIS Adapter Cable In Stock £24.84
HLJT Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £9.00
HLJT Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HLJT Poly - USB adapter - 24 pin USB-C to USB In Stock £13.36
Recommended Use: Computer
Connectivity: Wired
Earcover : Monaural
Brand: Poly
