The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
Enhanced call quality
Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback. -
Connectivity options
Enhanced connectivity for your devices with a USB-C cord and tethered USB-A adapter. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Lightweight design
A lightweight metal headband offers durability and a comfortable custom fit. -
Simple call management
Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 3220 - headset - USB-C
- Product Type
- Headset - wired - USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Additional Functions
- SoundGuard DIGITAL
- Black
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 6 dB RLR
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end, hold, redial
- Software Certification
- Skype Certified, Cisco Jabber Certified, Avaya Certified, UC certified
- Product Type
- Series
- Blackwire 3200 Series
- Compatibility
- Mac, Windows
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 92 g
- Black
- Earpad Material
- Foam
- Recommended Use
- 270° rotatable microphone, boom mic length 130 mm
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 6 dB RLR
- Impedance
- 32 Ohm
- Diaphragm
- 28 mm
- In-Cord Volume Control
- Dynamic EQ optimised, echo cancelation
Microphone
- Boom
- Omni-directional
- Sensitivity
- 10 dB SLR
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
- Software Included
- Poly Lens
- Included Accessories
- USB-C to USB-A adapter, USB-C cable
- Cable Details
- USB-C cable
- Supported Host Device OS
- Windows 11, Windows 10, macOS
- Shipping Width
- 18.5 cm
- Shipping Depth
- 5.6 cm
- Shipping Height
- 20.7 cm
- Shipping Weight
- 300 g
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.67 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.64 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
