Poly Blackwire 3220 headset - on-ear - wired - USB-C - black
Quicklinx: HXXWWS00 Mfr#: 8X228A6
Recommended Use: Computer, Portable electronics
Connectivity: Wired
More than 50 In Stock
£27.25 ex VAT
£32.70 inc VAT
The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
  • Enhanced call quality
    Dynamic EQ optimizes the quality of your voice on calls, and automatically adjusts the EQ settings when you want high-quality sound for listening to music or for multimedia playback.
  • Connectivity options
    Enhanced connectivity for your devices with a USB-C cord and tethered USB-A adapter.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Lightweight design
    A lightweight metal headband offers durability and a comfortable custom fit.
  • Simple call management
    Use the intuitive inline controls to answer/end calls, control volume, and mute to simplify call management. Conveniently placed indicator lights provide helpful but unobtrusive user call, mute, and volume status.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Blackwire 3220 - headset - USB-C
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 90 dB
Impedance
32 Ohm
Signal-To-Noise Ratio
118 dB
Microphone
Boom
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Mute, volume, answer/end, hold, redial
Software Certification
Skype Certified, Cisco Jabber Certified, Avaya Certified, UC certified
Series
Compatibility
Mac, Windows
15.5 cm
3.2 cm
17.8 cm
92 g
Earpad Material
Foam
Recommended Use
270° rotatable microphone, boom mic length 130 mm
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
118 dB
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
28 mm
In-Cord Volume Control
Dynamic EQ optimised, echo cancelation
Microphone
Boom
Omni-directional
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
USB-C to USB-A adapter, USB-C cable
Cable Details
USB-C cable
Supported Host Device OS
Windows 11, Windows 10, macOS
Shipping Width
18.5 cm
Shipping Depth
5.6 cm
Shipping Height
20.7 cm
Shipping Weight
242 g
HXXW Poly Spare Ear Cushion Foam for C310 & C320 In Stock £2.67
HXXW Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m In Stock £8.64
HXXW Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HXXW Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
HXXW Poly Spare Foam Ear Cushion BW3310 BW3320 In Stock £2.60
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
