The Blackwire 3200 Series provides a quality audio experience in a headset that's built for enterprise needs. With a sleek design and flexible microphone boom for a customizable fit, what's not to love?
- HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C
- Product Type
- Headset - wired - 3.5 mm jack, USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 ohm
- Signal-To-Noise Ratio
- 118 dB
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, answer/end, hold, redial
- Software Certification
- Certified for Skype for Business, Avaya Certified, Cisco Jabber Certified, UC certified
- Product Type
- Series
- Blackwire 3200 Series
- Compatibility
- Mac, Windows
- 15.5 cm
- 3.2 cm
- 17.8 cm
- 64 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Boom mic length 130 mm, 270° rotatable microphone
Audio Output
- On-ear monaural
- Wired
- 118 dB
- Sensitivity
- 116 dB
- Impedance
- 32 ohm
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Dynamic EQ optimised, echo reduction
Microphone
- Boom
- Omni-directional
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C) , Headphones (mini-phone 3.5mm)
- Included Accessories
- USB-C cable, USB-C to USB-A adapter, travel case
- Cable Details
- USB-C cable
- Supported Host Device OS
- Windows 10, macOS
- Shipping Width
- 18.5 cm
- Shipping Depth
- 5.6 cm
- Shipping Height
- 20.7 cm
- Shipping Weight
- 221 g
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £13.14 |
Poly Spare Ear Cushion Foam for C310 & C320 | In Stock | £2.71 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.30 |
