Efficient connectivity
The HP Poly audio cable is designed to provide a seamless connection between your audio devices. With a M22 connector on one end and a Quick Disconnect on the other, it ensures a stable and clear audio transmission, making it ideal for high-quality audio applications. -
Versatile compatibility
This audio cable's unique connector types, M22 and Quick Disconnect, offer broad compatibility with a range of audio equipment. Whether you're connecting professional audio gear or personal devices, this cable ensures reliable performance.
- Poly audio cable
- Cable
- Audio cable
- Connector
- M22
- Connector (Second End)
- Quick Disconnect
- Designed For
- Poly EncorePro
- Cable Type
- Audio cable
- Connector
- M22
- Quick Disconnect
- Shipping Width
- 13 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 7 cm
- Shipping Weight
- 300 g
- Designed For
- Poly EncorePro
