Make it your business to hear and be heard with the Voyager Focus UC stereo Bluetooth headset. Move fluidly between PC and smartphone and between work and entertainment with rich, immersive stereo sound and active noise canceling designed to keep your focus on work, not on the chaos around you.
Connect with ease
Premium wireless stereo headset works seamlessly across multiple applications on desktops, Bluetooth -enabled desk phones, laptops, mobile phones and tablets. -
Smart sensor technology
Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off. -
Focus on work–not the chaos around you
Shut the world out with on-demand active noise cancelation (ANC) that reduces distracting background sound in noisy environments so you can focus on your call or work. -
Outstanding audio quality
With three precisely tuned microphones and enhanced noise cancelling, optimize your voice and minimize noise caused by wind, movement, and background sounds so your caller hears you, not your surroundings. -
Worry-free mute assurance
Dedicated mute button gives you quick mute access while voice alert announces mute on/off status. Dynamic mute alert notifies you when you try to talk when muted, for worry-free mute assurance. -
Premium audio experience
High-quality, dual-ear design provides hi-fi stereo sound and a more immersive experience to enable focus in open work environments.
- Poly Voyager Focus B825-M - headset
- Product Type
- Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- MEMS-directional
- Microphones Included
- 3
- Controls
- Volume, answer/end, microphone on/mute, play/pause
- Software Certification
- Certified for Skype for Business, Certified for Microsoft Teams
- Product Type
- 18.3 cm
- 16 cm
- 7 cm
- 155 g
- Black
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 32 mm
- Simultaneously Connectable Devices Qty
- 8
- Smart Sensor Technology
Microphone
- Boom
- MEMS-directional
- 3
- 100 - 6700 Hz
Remote Control
- Controls
- Included Accessories
- Travel pouch, BT700 Bluetooth USB adapter
- Cable Details
- Micro-USB charging cable
- Battery
- Headset battery rechargeable
- Capacity
- 325 mAh
- Run Time (Up To)
- 15 hour(s)
- Run Time Details
- Continuous playback (AAC, active noise-cancelling on): up to 12 hours , Continuous talk (active noise-cancelling off): up to 12 hours , Continuous talk (active noise-cancelling on): up to 10 hours , Continuous playback (active noise-cancelling off): up to 15 hours
- Recharge Time
- 2 hour(s)
- Shipping Width
- 18.6 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 11.6 cm
- Shipping Weight
- 678.7 g
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £13.36 |
