Poly - Audio cable - M22 to Quick Disconnect - for Poly EncorePro
Quicklinx: J4K5WS00 Mfr#: 85R38AA
26 In Stock
£10.80 ex VAT
£12.96 inc VAT
The HP Inc. Poly audio cable stands out in the realm of audio connectivity solutions. Crafted with precision, it features a M22 connector on one end and a Quick Disconnect on the other, ensuring a seamless and stable connection between your devices. This cable is designed to support high-quality audio applications, providing clear and uninterrupted audio transmission. Its versatile compatibility makes it a valuable accessory for a wide array of audio equipment, from professional setups to personal audio devices. With its reliable performance and superior design, the HP Poly audio cable is an essential tool for anyone looking to enhance their audio experience.
  • Efficient connectivity
    The HP Poly audio cable is designed to provide a seamless connection between your audio devices. With a M22 connector on one end and a Quick Disconnect on the other, it ensures a stable and clear audio transmission, making it ideal for high-quality audio applications.
  • Versatile compatibility
    This audio cable's unique connector types, M22 and Quick Disconnect, offer broad compatibility with a range of audio equipment. Whether you're connecting professional audio gear or personal devices, this cable ensures reliable performance.
Poly audio cable
Cable
Audio cable
Connector
M22
Connector (Second End)
Quick Disconnect
Poly EncorePro
Cable Type
Audio cable
Connector
M22
Quick Disconnect
Shipping Width
13 cm
Shipping Depth
21 cm
Shipping Height
7 cm
Shipping Weight
300 g
Poly EncorePro
