Polaroid Music Player 3 - Yellow and White
Quicklinx: H79KWS00 Mfr#: 9090
Colours:
The Polaroid P3 is already an icon. This is THE design piece to own in the series of Polaroid players. The P3 is truly an object to display, not hide.
The Polaroid P3 Player has some real presence. Coming in around the dimensions of a pineapple (including the ‘crown’, which turns out to be the proper name of that top bit), it’s the choice to make for when more volume is needed. Plus, it’s still a portable speaker, thanks to its polished metal handle. And while none of the Polaroid Players are designed to blend in, the Polaroid P3 speaker is a true stand-out, bringing back big boombox energy with its retro-futuristic vibes. The Polaroid P3 also features the full functionality of the Polaroid Music App, meaning you can easily set up your favorite music channels and scroll through them with the analog dial.
  • Output power 35 W
    The most iconic music player.
  • Stereo pairing
    Connect another P3 for stereo sound.
  • Rechargeable battery
    Provides up to 15 hours of playback time.
Polaroid P3 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Frequency Response
100 - 20000 Hz
Amplifier
Integrated
NFC, Bluetooth
Yellow
Speaker battery rechargeable
30 cm x 7 cm x 14 cm
1.485 kg
1-year warranty
Qualcomm TrueWireless Stereo (TWS), stereo pairing
Enclosure Colour
Yellow
Enclosure Material
Nylon, polyester, iron, PP/PC, acrylonitrile butadiene styrene (ABS), thermoplastic polyurethane (TPU)
Speaker System
Speaker Type
Active
Frequency Response
100 - 20000 Hz
Sensitivity
75 dB
Amplifier
Integrated
Near Field Communication (NFC), Bluetooth 5.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Volume, play/pause, next track, previous track, activate Bluetooth
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
USB-C charging cable
Power Source
Rechargeable
Capacity (Ah)
4000 mAh
Voltage Provided
7.2 V
Run Time (Up To)
15 hour(s)
30 cm
7 cm
14 cm
1.485 kg
Limited warranty - 1 year
Resources
The following resources are available for the Polaroid Music Player 3 - Yellow and White
