Polaroid Music Player 2 - Red and White
Quicklinx: H791WS00 Mfr#: 9086
Colours:
The Polaroid P2 is a small but mighty Bluetooth speaker that doubles as a fashion accessory.
The player comes with a wrist strap that makes it super easy (and kinda cool) to carry around and the design is tactile, made to be held and felt. The P2 player is more than twice as powerful as the P1. If you can, close your eyes and imagine two bananas. Well done. You’ve just imagined the size of the Polaroid P2 Player. It’s twice as powerful as the Polaroid P1 and just as take-anywhere-able. It’s also a wearable speaker - on your wrist, over your shoulder, as a necklace, or on your head – there are no wrong choices here. The Polaroid P2 speaker is the first player in the line-up to work with all the features of the Polaroid Music App - letting you play your favorite playlists with just a spin of the analog dial. It’s powerful for its size, easily portable, colorful, and iconic in design.
  • Output power 20 W
    The most wearable music player.
  • Stereo pairing
    Connect another P2 for stereo sound.
  • Rechargeable battery
    Provides up to 15 hours of playback time.
Polaroid P2 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Frequency Response
165 - 20000 Hz
Amplifier
Integrated
NFC, Bluetooth
Red
Speaker battery rechargeable
22 cm x 5 cm x 9 cm
660.2 g
1-year warranty
Qualcomm TrueWireless Stereo (TWS), stereo pairing
Enclosure Colour
Red
Enclosure Material
Nylon, polyester, iron, PP/PC, acrylonitrile butadiene styrene (ABS), thermoplastic polyurethane (TPU)
Speaker System
Speaker Type
Active
Frequency Response
165 - 20000 Hz
Sensitivity
75 dB
Amplifier
Integrated
Near Field Communication (NFC), Bluetooth 5.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Controls
Volume, play/pause, next track, previous track, activate Bluetooth
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Wrist strap, carabiner, USB-C charging cable
Power Source
Rechargeable
Capacity (Ah)
2500 mAh
Voltage Provided
7.2 V
Run Time (Up To)
15 hour(s)
Recharge Time
4 hour(s)
22 cm
5 cm
9 cm
660.2 g
Limited warranty - 1 year
Resources
The following resources are available for the Polaroid Music Player 2 - Red and White
