Upgrading a standard laptop or desktop with a system drive may be hard sometimes. PNY SSD Upgrade Kit is the ideal accessory to help you jumping to a system solution for both laptops and desktops. Including an external USB enclosure to ease the cloning, a 3.5" to 2.5" mounting bay, as well as the compliant connectivity and a clone software, upgrading has never been that easy!
- PNY SSD Accessories Kit - storage enclosure - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Devices
- Hard drive, solid state drive
- 2.5"
- Host Bus
- USB 3.0
Storage Controller
- Supported Devices
- Bays
- Connections
- 1 x USB 3.0
- Included Accessories
- 3.5" to 2.5" bay adapter, screwdriver, screws
- Cables Included
- 1 x USB cable , 1 x Serial ATA cable
- Mounting Kit
- Included
- Software Included
- Acronis True Image HD
