PNY Quadro NVS 510 2GB DDR3 128bit PCIEx16 DP Low Profile
Quicklinx: 8H4SWS00 Mfr#: VCNVS510DP-PB
The NVIDIA NVS 510 offers the latest in graphics and display technologies along with industry-leading, multi-display management capabilities in a power-friendly, low-profile form factor. This makes it the ideal graphics solution for professionals who need to efficiently visualize and digest a great deal of information in the financial trading, command and control, and digital-signage markets.
  • Quad Display Support
    All-new NVS 510 display engine drives up to four displays simultaneously and fully supports the next generation Display Port 1.2 standard capable of resolutions such as 3,840 x 2,160 at 60Hz. NVS 510, when used with the nView Desktop Software utility, makes it easy to deploy multiple displays across a desktop or build an expansive digital signage wall.
  • New DisplayPort 1.2 Features (with Audio)
    NVS 510's integrated DisplayPort 1.2 Engine produces phenomenal photorealistic image quality while driving ultra-high-resolution panels (up to 3,840 x 2,160 at 60Hz). NVS 510 also supports advanced Display Port 1.2 features like multi-stream technology (MST) and stream cloning, which enable efficient cable management. MST allows an end-user to drive up to for independent displays simultaneously from any one display port output, while stream cloning enables NVS 510 to clone up-to four instances of each display output to drive a maximum of 16 displays.
  • Versatile Connectivity Options using Mini DisplayPort Connector
    End users can securely connect to the most exhaustive options of display monitors and HDMI capable devices either by using the included mini-DP to Display Port adapters to take advantage of widely deployed DiplayPort cables and dongles, or directly connect using mini DisplayPort based cables and dongles.
  • Multi-Display Experience with NVIDIA Mosaic Technology
    Enables seamless taskbar spanning as well as transparent scaling of the desktop and applications across up to 8 displays (using two NVS 510 Graphics Cards) from a single workstation or PC while delivering full performance and image quality.
  • NVIDIA High-Definition Video Technology
    Combines high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing, inverse telecine and high quality dual HD video playback - with low CPU utilization and power consumption.
  • H.264 Encoder
    Dedicated H.264 encode engine that's independent of the 3D or compute pipeline which delivers faster than real-time performance for transcoding, video editing, and other encoding applications.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and new film-style AA techniques.
NVIDIA NVS 510 by PNY - graphics card - NVS 510 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA NVS 510
2 GB DDR3
CUDA Cores
192
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Monitors Supported
4
4 x Mini DisplayPort , 4 x DisplayPort - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
16 cm x 6.89 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA NVS 510
CUDA Cores
192
Max Resolution
3840 x 2160 at 60 Hz
4
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, TXAA, Dual-stream Hardware Acceleration, GPU Tessellation, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture, HDCP
Size
2 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
28.5 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
33.4 Watt
Low-profile bracket
4 x Mini DisplayPort-DisplayPort cable
Software Included
Drivers & Utilities, Nvidia nView Desktop Management Software
UL, WHQL
16 cm
6.89 cm
ENERGY STAR Certified
Limited warranty - 3 years
8H4S C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black In Stock £15.26
