PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2
Quicklinx: 8LCMWS00 Mfr#: VCQK600-PB
  • DisplayPort
The NVIDIA Quadro K600 graphics board offers great performance and outstanding features at an affordable price for a wide range of leading professional applications. You get 1GB of on-board DDR3 GPU memory, 192 SMX CUDA parallel processing cores, and full Shader Model 5 compatibility; all in a low-profile form factor for maximum system flexibility.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether it's product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster, more profitably, and with superior visual quality.
  • NVIDIA CUDA architecture
    Parallel-computing architecture that tightly integrates advanced visualization and compute features to significantly accelerate professional workflows.
  • NVIDIA scalable geometry engine
    Dramatically improves geometry performance across a broad range of CAD, DCC and medical applications, enabling you to work interactively with models and scenes that are an order of magnitude more complex than ever before.
  • Large framebuffers with ultra-fast bandwidth
    Large GPU memory with fast bandwidth for display of complex models and scenes, as well as computation of large datasets.
  • NVIDIA Parallel DataCache
    Supports a true cache hierarchy combined with on-chip shared memory. L1 and L2 caches drive exceptional throughput, accelerating features such as real-time ray tracing, physics, and texture filtering.
  • Unified Driver Architecture (UDA)
    Guarantees forward and backward compatibility with software drivers. This simplifies upgrading to a solution because all Quadro-based products work with the same driver software.
  • Bindless textures
    Dramatically increases the number of unique textures available to shaders at run-time, enabling vastly more different materials and richer texture detail in scenes.
  • NVIDIA SMX
    Delivers more processing performance and efficiency through this streaming multiprocessor design that allows a greater percentage of space to be applied to processing cores versus control logic.
  • H.264 encoder
    Dedicated H.264 encode engine that' independent of 3D/compute pipeline and delivers faster than real-time performance for transcoding, video editing, and other encoding applications.
  • Ultra-quiet design
    Silent cooling design enables acoustics lower than 28 dB for an ultra-quiet desktop environment.
  • Full-Scene Antialiasing (FSAA)
    Up to 64x FSAA for dramatically reducing visual aliasing artifacts or "jaggies," resulting in unparallel image quality and highly realistic scenes.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and film-style AA techniques.
  • GPU Tessellation with Shader Model 5.0
    Quadro Tessellation Engines automatically generate finely detailed geometry for cinematic quality environments and scenes, without sacrificing performance.
  • 16K texture and render processing
    Provides the ability to texture from and render to 16K x 16K surfaces. Beneficial for applications that demand the highest resolution and quality image processing.
  • NVIDIA Quadro Mosaic technology
    Enables transparent scaling of the desktop and applications across up to 16 displays from 4 GPUs from a single workstation while delivering full performance and image quality.
  • Deep color processing and display
    Preserve color detail and precision throughout the processing and display pipeline for smooth gradients and transitions, even on high dynamic range imagery. Each color component can be processed at up to 32-bit floating point precision and displayed at up to 12-bit precision with supported DisplayPort 1.2 or HDMI displays.
  • NVIDIA 3D Vision and 3D Vision Pro
    Advanced active shutter glasses that deliver crystal-clear stereoscopic 3D visualization for the most immersive experience. Infrared (3D Vision) or RF (3D Vision Pro) technology enable a range of immersive environments from your desktop workstation to collaborative work spaces.
  • Professional 3D stereo synchronization
    Provides a smooth and immersive 3D Stereo experience for professional applications. Stereo synchronization is supported via the USB hub input offered by NVIDIA 3D Vision Pro or 3D Vision products.
NVIDIA Quadro K600 - graphics card - Quadro K600 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K600
1 GB DDR3
CUDA Cores
192
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
2
Interfaces Details
DVI-I (dual link) , DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
16 cm x 6.89 cm
Package Type
Retail
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K600
CUDA Cores
192
RAMDAC
400 MHz
Max Resolution
2
Interfaces Details
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, NVIDIA Parallel DataCache, NVIDIA Mosaic, Shader Model 5.0, Nvidia 3D Vision Pro, TXAA, SMX technology, Nvidia Fast Approximate Antialiasing Technology (FXAA), Bindless Textures, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
29 GBps
SunSoft Solaris, Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
41 Watt
Low-profile bracket, full-height bracket
1 x DVI-VGA adapter , 1 x DisplayPort-DVI adapter
Software Included
Drivers & Utilities
UL, RoHS
16 cm
6.89 cm
Package Type
Retail
ENERGY STAR Certified
Limited warranty - 3 years
8LCM C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.54
8LCM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.42
8LCM C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.94
Resources
The following resources are available for the PNY Quadro K600 Kepler 1GB DDR3 128bit PCIE 2.0 LP DVI-I DP1.2
