Your basket is empty
PNY Quadro K2000D Kepler 2GB GDDR5 128bit 2xDVI 1xmDP
Quicklinx: 8LCSWS00 Mfr#: VCQK2000DVI-PB
  • DisplayPort
The NVIDIA Quadro K2000D graphics board offers the perfect blend of performance and the latest productivity enhancing technical innovations at a very reasonable cost for a wide range of leading professional applications. With two DVI-DL connectors, and the ability to drive an additional side display, the K2000D is an ideal choice for color or grayscale medical imaging applications requiring 10 or 12-bit grayscale imaging with DICOM monitor calibration support. You get GDDR5 GPU memory, 384 SMX CUDA parallel processing cores, and full Shader Model 5 compatibility; all in a single slot form factor which requires no auxiliary power to deliver full performance.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 150 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most demanding needs - whether it's product design, visualization and simulation, or medical and diagnostic imaging.
NVIDIA Quadro K2000D - graphics card - Quadro K2000D - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
2 GB GDDR5
CUDA Cores
384
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
2 x DVI-I (dual link) , Mini DisplayPort , VGA - with adapter
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
20 cm x 11 cm
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
CUDA Cores
384
RAMDAC
400 MHz
Max Resolution
4
API Supported
NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, Deep Color technology, Shader Model 5.0, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, TXAA, SMX technology, GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Nvidia Quadro Mosaic Technology, Bindless Textures, Multi-Stream Technology, HDCP
Size
2 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
64 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
51 Watt
2 x DVI-VGA adapter , 1 x Mini DisplayPort-DVI adapter , 1 x Mini DisplayPort-DisplayPort adapter
Software Included
Drivers & Utilities
20 cm
11 cm
Resources
The following resources are available for the PNY Quadro K2000D Kepler 2GB GDDR5 128bit 2xDVI 1xmDP
