Build cost-effective, reliable signage solutions with the 8 display output, single slot form factor NVIDIA® NVS™ 810
The NVIDIA NVS 810 graphics board delivers exceptional display connectivity, cost-effective scalability, and image management capabilities that make it easy to drive any kind of multi-display digital signage setup. It’s the first of its kind to offer eight display outputs, combined with the world’s most advanced GPU architecture—all in a single-slot form factor. NVS 810 is also ideal for creating dense signage solutions, delivering the uncompromised performance and reliability required to deploy demanding content in mission-critical signage installations.
Eight mini-DisplayPort 1.2 connectors on the NVIDIA NVS 810 are capable of driving UHD 4K displays at 60 Hz. Plus, it provides advanced features like multi-streaming and stream cloning that enable extremely efficient cable management and display flexibility in complex installations. Key NVIDIA features like bezel correction, synchronization across 8 displays, Warp & Blend, and Mosaic make digital signage easy. This configuration of the NVS 810 includes eight locking mini-DisplayPort to DVI-D SL adapters for installations requiring DVI displays.
PNY provides unsurpassed service and commitment to its professional graphics customers including a 3 year warranty, pre- and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, and a driver and documentation software installation disc to ensure a quick and successful install.
Energy efficient
Certified by ENERGY STAR, this graphics card ensures optimal energy efficiency, reducing power consumption to just 68 W during operation. -
High-definition visuals
With support for up to 8 monitors and a maximum external resolution of 4096 x 2160, the NVIDIA NVS 810 delivers stunning, high-definition visuals across multiple displays. -
Expansive connectivity
Equipped with 8 Mini DisplayPort interfaces, this graphics card offers versatile connectivity options for a wide range of display setups. -
Advanced graphics processing
Featuring 1024 CUDA cores and dual NVIDIA graphics processors, the NVS 810 excels in delivering powerful computing performance for graphics-intensive applications. -
Enhanced display technology
Incorporates NVIDIA's Mosaic, Quadro Warp/Blend, and nVIEW Multi-Display Technology for flexible and seamless multi-display arrangements.
- NVIDIA NVS 810 - graphics card - 2 GPUs - NVS 810 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- 2 GPUs - NVIDIA NVS 810
- Memory
- 4 GB DDR3
- CUDA Cores
- 1024
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 8
- Interfaces Details
- 8 x Mini DisplayPort , 8 x DVI - with adapter
- API Supported
- DirectX 11, OpenCL, DirectCompute, OpenGL 4.3
- 19.8 cm x 11.2 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- CUDA Cores
- 1024
- Max Resolution
- 4096 x 2160 at 60 Hz
- 8
- API Supported
- NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, TXAA, FXAA, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, NVIDIA GPU Boost, Multi-stream hardware H.264 encoder, Nvidia Quadro Warp/Blend, Bezel Compensation, Maxwell architecture, ultra-quiet active fansink, HDCP
- Size
- 4 GB
- Technology
- DDR3 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 28.8 GBps
- OS Required
- Linux, Oracle Solaris, Windows 8, Windows 8.1, Windows 10
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- CD-ROM
- 68 Watt
- Cables Included
- 8 x Mini DisplayPort-DVI adapter
- Software Included
- Drivers & Utilities, Nvidia nView Desktop Management Software
- WHQL
- 19.8 cm
- 11.2 cm
- 468 g
- ENERGY STAR Certified
- Limited warranty - 3 years
