PNY Nvidia Quadro M5000 Graphics Card
Quicklinx: BL72WS00 Mfr#: VCQM5000-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. NVIDIA's advanced Maxwell GPU architecture delivers incredible performance to let you unleash your creativity and conquer extreme workloads with ease. 8 GB of ultra-fast memory with ECC lets you create and render large, complex models and compute massive datasets, all with ECC support for added reliability. A new display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color). Pair up two or more outputs to drive displays greater than 4K, and take advantage of NVIDIA Quadro Sync support to frame-lock multiple displays together (see PNY PN VCQM6000SYNC-PB), or use external I/O boards and NVIDIA's GPUDirect for Video to integrate the Quadro M5000 into broadcast, video or film production workflows.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
  • Energy efficient
    With ENERGY STAR certification, this graphics card ensures optimal energy efficiency, reducing power consumption and lowering energy costs.
  • High-resolution support
    Supports up to 4096 x 2160 resolution across four monitors, providing stunning clarity and detail for professional applications and gaming.
  • Advanced cooling
    Features a dual slot fan cooler and an ultra-quiet active fansink, designed to maintain optimal performance by efficiently dissipating heat.
  • Versatile connectivity
    Equipped with multiple output ports including 4 x DisplayPort, DVI, and VGA with adapters, offering flexible connectivity options for various display setups.
  • Robust video memory
    Comes with a 256-bit wide GDDR5 SDRAM interface and a bandwidth of 211 GBps, enabling fast and smooth rendering of complex models and textures.
NVIDIA Quadro M5000 - graphics card - Quadro M5000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M5000
8 GB GDDR5
CUDA Cores
2048
RAMDAC
400 MHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
4
DVI-D (dual link) , 4 x DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter , DVI-D (Single-Link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
26.7 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M5000
CUDA Cores
2048
RAMDAC
400 MHz
Max Resolution
4
API Supported
Nvidia GeForce 3D Stereo technology, Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Shader Model 5.0, Dolby Digital Plus, GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Full 30-bit Display Pipeline, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
211 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection
150 Watt
6 pin power cable, stereo connector bracket
2 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
Software Included
Display drivers
26.7 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
BL72 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.57
BL72 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £14.94
