PNY NVIDIA Quadro M4000 Sync 8GB GDDR5 PCI-E 3.0 X16 4*DP
Quicklinx: BWFQWS00 Mfr#: VCQM4000SYNC-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. Tackle your most demanding visualization workloads with ease using the advanced NVIDIA Maxwell GPU architecture and the flexibility of a single-slot form factor. 8 GB of ultra-fast memory enables the creation and rendering of large, complex models and the computation of massive datasets. A display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color), or pair up two or more outputs to drive displays greater than 4K.
The NVIDIA Quadro Sync board included as part of this turnkey solution synchronizes up to four NVIDIA Maxwell architecture-based GPUs and up to 16 displays or projectors per system. Quadro Sync benefits include the ability to keep multi-projector systems or video walls free of imaging artifacts without impacting performance, the ability to align inputs for multi-input display devices like 4K projectors or panels, proper stereoscopic 3D display across multiple systems, and the ability to align displays or projectors to an external timing source. NVIDIA Mosaic technology support allows any application to scale across synchronized displays or projectors and offers features like projector overlap and an integrated geometry and intensity adjustment to enable pixel-accurate display surfaces.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
  • Maxwell Streaming Multiprocessor
    The heart of Maxwell' power efficient performance is its designed Streaming Multiprocessor which delivers incredible performance and unmatched power efficiency, through an improved instruction scheduler and new data path organization.
  • Maxwell memory architecture
    Improved caching effectiveness and significant enhancements in memory compression techniques in Maxwell reduces traffic and provides higher performance for applications dependent on memory bandwidth. Additionally, Maxwell's dedicated shared memory per SM (separated from the L1 cache) and larger L2 cache, dramatically improves programmability and efficiency.
  • Viewport multicast
    Dedicated hardware to automatically broadcast input geometry to render to multiple render targets which drastically speeds up 'multi projection(the ability of rendering the same scene from multiple view) leading to accelerated rendering for cube maps used in multi view projectors and 3D CAVE environments.
  • Sparse textures
    Virtualizes texture sizes enabling applications to seamlessly work with large and complex data sets regardless of the available frame buffer.
  • Accelerated voxelization
    Enhancements to voxel handling techniques enables fast voxelization which significantly accelerates workflows like fluid simulation and 3D printing.
  • Multiple copy engines
    Enables the highest rates of parallel data processing and concurrent throughput between the GPU and host, accelerating techniques such as ray tracing, color grading and physical simulation.
  • Bindless graphics
    Optimizes GPU utilization by dramatically reducing CPU-GPU interactions, enabling developers to implement more sophisticated and complex algorithms providing end users greater performance and higher levels of visual fidelity.
  • H.264 and HEVC encoder
    Dedicated H.264 and HEVC encode engine that is independent of 3D/compute pipeline and delivers faster than real-time performance for transcoding, video editing, and other encoding applications.
  • NVIDIA CUDA architecture
    Parallel-computing architecture that tightly integrates advanced visualization and compute features to significantly accelerate professional workflows.
  • NVIDIA scalable geometry engine
    Dramatically improves geometry performance across a broad range of CAD, DCC and medical applications, enabling you to work interactively with models and scenes that are an order of magnitude more complex than ever before.
  • Dynamic parallelism
    Simplifies GPU programming by allowing programmers to easily accelerate all parallel nested loops - resulting in a GPU dynamically spawning new threads on its own without going back to the CPU.
  • Large framebuffers with ultra-fast bandwidth
    Large GPU memory with fast bandwidth for display of complex models and scenes, as well as computation of large datasets.
  • PCI Express 3.0 compliance
    Supports data transfer rate up to 8 GT/sec per lane for an aggregate bandwidth of 32 GB/sec bi-directional (16 GB/sec in each direction.)
  • Ultra-quiet design
    Silent cooling design enables lower acoustics for an ultra-quiet desktop environment.
  • Full-Scene Antialiasing (FSAA)
    Up to 64X FSAA for dramatically reducing visual aliasing artifacts or "jaggies," resulting in unparalled image quality and highly realistic scenes.
  • NVIDIA FXAA and TXAA
    Reduces visible aliasing and delivers higher image quality without the performance hit by harnessing the power of the GPU's CUDA cores and film-style AA techniques.
  • GPU tessellation
    Quadro Tessellation Engines automatically generate finely detailed geometry for cinematic quality environments and scenes, without sacrificing performance.
  • 16K texture and render processing
    Provides the ability to texture from and render to 16K x 16K surfaces. Beneficial for applications that demand the highest resolution and quality image processing.
  • NVIDIA Quadro Mosaic technology
    Enables transparent scaling of the desktop and applications across up to 16 displays from 4 GPUs from a single workstation while delivering full performance and image quality.
  • Multi-display support
    The display engine drives up to four displays simultaneously and fully supports the next generation Display Port 1.2 standard capable of resolutions such as 3840 x 2160 at 60Hz, making it easy to deploy multiple displays across a desktop, build an expansive digital signage wall, or create a sophisticated stereoscopic 3D CAVE environment.
  • NVIDIA NVIEW advanced desktop software
    This software delivers maximum flexibility for single large display or multi-display options, providing unprecedented end-user control of the desktop experience for increased productivity.
  • DisplayPort 1.2 support (with Audio)
    Compact and secure DisplayPort 1.2 connectors support multi-stream technology, stream cloning and ultra-high-resolution panels (up to 3840 x 2160 at 60Hz). This enables maximum range, resolution, refresh rate, and color depth designed to support the latest display technologies.
  • OpenGL quad buffered stereo support
    Provides a smooth and immersive 3D Stereo experience for professional applications.
  • Professional 3D stereo synchronization
    Enables robust control of stereo effect through a dedicated three-pin mini-din connection to directly synchronize 3D stereo hardware to Quadro graphics card.
  • Deep color processing and display
    Preserve color detail and precision throughout the processing and display pipeline for smooth gradients transitions, even on high dynamic range imagery. Each color component can be processed at up to 32-bit floating point precision and displayed at up to 12-bit precision with supported DisplayPort 1.2 or HDMI 1.4 displays.
  • Quadro Sync
    Ensures image and frame synchronization between up to four GPUs when running Quadro Mosaic or independent GPUs in clusters. Quadro Sync also allows synchronization to an external timing source (also known as genlock or house sync). Quadro Sync enables advanced visualization systems to scale the resolution of the display surface with multiple projectors or displays with standard applications or applications designed for clusters.
  • Framelock RJ-45 connectors
    Allows display channels from multiple systems to be synchronized, creating one large virtual display. The resulting virtual display can be driven by a multi-system cluster for performance scalability. For frame lock applications, the Quadro Sync board has to be connected to one or more additional Quadro Sync boards.
  • Genlock (House Synchronization) BNC connector
    One analog or digital genlock connector provides connectivity to a video sync source for SMPTE standard (digital, black burst, tri-level) synchronization. Expanded cross sync functionality permits an incoming house signal to synchronize a much larger number of video output signal formats.
  • Supports up to four NVIDIA Maxwell architecture Quadro GPUs
    Each Quadro Sync board is capable of supporting up to four GPUs with up to 16 displays. For additional performance scalability multiple nodes can be connected into a cluster.
  • Windows management instrumentation support
    Industry-standard WMI interfaces make it easy to script and remotely manage Quadro Sync and other GPU features on any system within a visualization cluster.
NVIDIA Quadro M4000 Sync - graphics card - Quadro M4000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
8 GB GDDR5
CUDA Cores
1664
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
4 x DisplayPort , DVI-D (Single-Link) - with adapter , DVI-D (dual link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
24.1 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bundled with
NVIDIA Quadro Sync add-on interface board
Graphics card
Bundled with
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
CUDA Cores
1664
Max Resolution
4
API Supported
Dual Slot Fan Cooler, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), 128-bit floating point HDR rendering, Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Full 30-bit Display Pipeline, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16x angle invariant anisotropic texture filtering, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection
120 Watt
Stereo connector bracket, 6 pin PCIe power cable, 3 x cable retention clips, 4 x ribbon connector cables
Software Included
Display drivers
24.1 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
BWFQ C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.48
BWFQ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.35
BWFQ C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.71
