PNY Nvidia Quadro M4000 Graphics Card
Quicklinx: BL73WS00 Mfr#: VCQM4000-PB
Get real interactive expression with NVIDIA Quadro - the world's most powerful workstation graphics. Tackle your most demanding visualization workloads with ease using the advanced NVIDIA Maxwell GPU architecture and the flexibility of a single-slot form factor. 8 GB of ultra-fast memory enables the creation and rendering of large, complex models and the computation of massive datasets. A new display engine drives up to four 4K resolutions displays natively (4096 x 2160 at 60 Hz with 30-bit color). Pair up two or more outputs to drive displays greater than 4K, and take advantage of NVIDIA Quadro Sync support to frame-lock multiple displays together or use external I/O boards and NVIDIA's GPUDirect for Video to integrate the Quadro M4000 into broadcast, video or film production workflows.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
  • Maxwell streaming multiprocessor
    The heart of Maxwell' power efficient performance is its newly designed Streaming Multiprocessor which delivers incredible performance and unmatched power efficiency, through an improved instruction scheduler and data path organization.
  • Sparse textures
    Virtualizes texture sizes enabling applications to seamlessly work with large and complex data sets regardless of the available frame buffer.
  • Accelerated voxelization
    Enhancements to voxel handling techniques enables fast voxelization which significantly accelerates workflows like fluid simulation and 3D printing.
  • Multiple copy engines
    Enables the highest rates of parallel data processing and concurrent throughput between the GPU and host, accelerating techniques such as ray tracing, color grading and physical simulation.
  • Bindless graphics
    Optimizes GPU utilization by dramatically reducing CPU-GPU interactions, enabling developers to implement more sophisticated and complex algorithms providing end users greater performance and higher levels of visual fidelity.
  • NVIDIA CUDA architecture
    Parallel-computing architecture that tightly integrates advanced visualization and compute features to significantly accelerate professional workflows.
  • NVIDIA scalable geometry engine
    Dramatically improves geometry performance across a broad range of CAD, DCC and medical applications, enabling you to work interactively with models and scenes that are an order of magnitude more complex than ever before.
  • Large framebuffers with ultra-fast bandwidth
    Large GPU memory with fast bandwidth for display of complex models and scenes, as well as computation of large datasets.
  • Ultra-quiet design
    Silent cooling design enables lower acoustics for an ultra-quiet desktop environment.
  • Full-scene antialiasing (FSAA)
    Up to 64X FSAA for dramatically reducing visual aliasing artifacts or "jaggies," resulting in unparalled image quality and highly realistic scenes.
  • GPU tessellation
    Quadro Tessellation Engines automatically generate finely detailed geometry for cinematic quality environments and scenes, without sacrificing performance.
  • 16K texture and render processing
    Provides the ability to texture from and render to 16K x 16K surfaces. Beneficial for applications that demand the highest resolution and quality image processing.
  • NVIDIA Quadro Mosaic technology
    Enables transparent scaling of the desktop and applications across up to 16 displays from 4 GPUs from a single workstation while delivering full performance and image quality.
  • NVIDIA 3D vision
    Advanced active shutter glasses that deliver crystal-clear stereoscopic 3D visualization for the most immersive experience. 3D Vision and 3D Vision Pro are sold separately.
NVIDIA Quadro M4000 - graphics card - Quadro M4000 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
8 GB GDDR5
CUDA Cores
1664
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
4 x DisplayPort , DVI-D (Single-Link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
24.1 cm x 11.2 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA Quadro M4000
CUDA Cores
1664
Max Resolution
4
API Supported
Nvidia GeForce 3D Stereo technology, Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia SMX Engine, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16x angle invariant anisotropic texture filtering, ultra-quiet active fansink, 16K Texture and Render Processing, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Bandwidth
192 GBps
Linux, Microsoft Windows Vista, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM, Internet connection, 6 pin PCI Express power connector
120 Watt
6 pin power cable, stereo connector bracket
1 x DisplayPort to DVI-D (SL) adapter
Software Included
Display drivers
24.1 cm
11.2 cm
ENERGY STAR Certified
Limited warranty - 3 years
BL73 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.54
BL73 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.42
BL73 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.94
