The Quadro M2000 delivers an incredible creative experience across a broad range of professional 3D applications. This advanced graphics card features and NVIDIA Maxwell-based GPU, 4 GB of ultra-fast on-board memory and the power to drive four 4K displays natively. This makes it an excellent choice for accelerating product development and content creation workflows that demand fluid interactivity with complex models and scenes. Creative professionals can tap into this increased performance - as well as hardware HEVC encode and decode engines - to accelerate both creation and playback of HEVC content.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 100 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
- NVIDIA Quadro M2000 - graphics card - Quadro M2000 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 4 GB GDDR5
- CUDA Cores
- 768
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI (Single-Link): 1920 x 1200 / DVI (Dual-Link): 2560 x 1600 / DisplayPort: 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- 4 x DisplayPort , DVI-D (Single-Link) - with adapter
- API Supported
- OpenCL, DirectCompute, DirectX 12, OpenGL 4.5, Vulkan
- 16.8 cm x 11.1 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, Deep Color technology, DTS-HD Master Audio support, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, 64X Anti-aliasing Technology, integrated MPEG-2 decoder, Full-Scene Anti-Aliasing (FSAA), Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, 128-bit floating point HDR rendering, Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Nvidia Quadro Mosaic Technology, linear pulse-code modulation (LPCM) support, Unified Driver Architecture (UDA), Nvidia Temporal Anti-Aliasing Technology (TXAA), Maxwell architecture, 16K Texture and Render Processing, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 106 GBps
- OS Required
- Linux, Oracle Solaris, Microsoft Windows 7 / 8 / 8.1 / 10
- Min RAM Size
- 2 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM, Internet connection
- 75 Watt
- Cables Included
- 1 x DisplayPort-DVI adapter
- Software Included
- Display drivers
- DisplayPort 1.2
- 16.8 cm
- 11.1 cm
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
