PNY Nvidia Quadro K620 2GB PCI-E X16 DDR3 DVI-I
Quicklinx: 9PWQWS00 Mfr#: VCQK620-PB
  • DisplayPort
The NVIDIA Quadro K620 offers impressive power-efficient 3D application performance and capability. 2 GB of DDR3 GPU memory with fast bandwidth enables you to create large, complex 3D models, and a flexible single-slot and low-profile form factor makes it compatible with even the most space and power-constrained chassis. Plus, an all-new display engine drives up to four displays with DisplayPort 1.2 support for ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
  • Energy efficient
    ENERGY STAR certification ensures that the NVIDIA Quadro K620 graphics card meets strict energy efficiency guidelines, making it an ideal choice for environmentally conscious users seeking to reduce their carbon footprint and energy costs.
  • High-resolution support
    With support for resolutions up to 3840 x 2160 at 60 Hz, the NVIDIA Quadro K620 offers stunning visual clarity and detail for professional applications, ensuring that designers, engineers, and multimedia professionals can work on complex projects with precision.
  • Versatile connectivity
    Featuring a range of output ports including DVI, DisplayPort, and VGA with adapters, the NVIDIA Quadro K620 provides flexible connectivity options, allowing users to connect multiple displays and devices for an enhanced workflow.
  • Advanced graphics features
    The NVIDIA Quadro K620 comes equipped with a suite of NVIDIA technologies such as Mosaic, nVIEW Multi-Display Technology, and hardware video decode acceleration, offering professionals the tools they need for efficient multitasking and high-quality graphics rendering.
  • Robust memory performance
    With a 128-bit memory interface and 29 GBps bandwidth, the NVIDIA Quadro K620's DDR3 SDRAM technology delivers the speed and performance required for demanding applications, ensuring smooth and responsive operation.
NVIDIA Quadro K620 - graphics card - Quadro K620 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K620
2 GB DDR3
CUDA Cores
384
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
Max Monitors Supported
2
DVI-I (dual link) , DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter
API Supported
OpenCL, DirectCompute, DirectX 11.2, OpenGL 4.5
16 cm x 6.89 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K620
CUDA Cores
384
RAMDAC
400 MHz
Max Resolution
2
API Supported
Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Hardware Video Decode Acceleration, Shader Model 5.0, Nvidia 3D Vision Pro, FXAA, SMX technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), HDCP
Size
2 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
29 GBps
Linux, Microsoft Windows 7, Microsoft Windows Vista, Oracle Solaris, Windows 8, Windows 8.1
Min RAM Size
1 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
41 Watt
Full-height bracket
1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
Software Included
Drivers & Utilities
16 cm
6.89 cm
ENERGY STAR Certified
Limited warranty - 3 years
9PWQ C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.78
9PWQ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.43
