The NVIDIA Quadro K5200 gives you amazing application performance and capability, making it faster and easier to accelerate 3D models, render complex scenes, and simulate large datasets. 8 GB of GDDR5 GPU memory with ultra-fast bandwidth allows you to create and render large, complex models and compute massive datasets. Plus, there's the display engine that drives up to four displays natively with DisplayPort 1.2 support for ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color.
The NVIDIA Quadro Sync board included as part of this turnkey solution synchronizes up to four NVIDIA Kepler architecture-based GPUs and up to 16 displays or projectors per system. Quadro Sync benefits include the ability to keep multi-projector systems or video walls free of imaging artifacts without impacting performance, the ability to align inputs for multi-input display devices like 4K projectors or panels, proper stereoscopic 3D display across multiple systems, and the ability to align displays or projectors to an external timing source. NVIDIA Mosaic technology support allows any application to scale across synchronized displays or projectors and offers features like projector overlap and an integrated geometry and intensity adjustment to enable pixel-accurate display surfaces.
- NVIDIA Quadro K5200 Sync - graphics card - Quadro K5200 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 8 GB GDDR5
- CUDA Cores
- 2304
- RAMDAC
- 400 MHz
- Memory Interface
- 256-bit
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
- Max Monitors Supported
- 4
- DVI-I (dual link) , DVI-D (dual link) , 2 x DisplayPort , VGA - with adapter , DVI-D (Single-Link) - with adapter
- API Supported
- OpenCL, DirectCompute 5.0, DirectX 11.2, OpenGL 4.5
- 26.7 cm x 11.1 cm
- Package Type
- Retail
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bundled with
- NVIDIA Quadro Sync add-on interface board
- Graphics card
- Bundled with
- Bus Type
- Graphics Engine
- CUDA Cores
- 2304
- RAMDAC
- 400 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- Nvidia GeForce 3D Stereo technology, Nvidia SLI Multi-GPU Technology, Dual Slot Fan Cooler, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Error Correcting Codes (ECC) Memory, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Hardware Video Decode Acceleration, Shader Model 5.0, Nvidia 3D Vision Pro, FXAA, SMX technology, Dual Copy Engines, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Dynamic Parallelism, Hyper-Q, Nvidia Quadro Mosaic Technology, Quadro Sync, Nvidia GPUDirect, Bindless Textures, Nvidia Quadro Warp/Blend, Nvidia Temporal Anti-Aliasing Technology (TXAA), HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 256-bit
- Bandwidth
- 192 GBps
- OS Required
- SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 150 Watt
- Included Accessories
- Stereo connector bracket, 4 x cable retention clips, 3 x connector clips
- Cables Included
- 1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities
- 26.7 cm
- 11.1 cm
- Package Type
- Retail
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
