PNY NVIDIA QUADRO K420 2GB DDR3 128-bit PCI-E X16 DL-DVI-I DisplayPort
Quicklinx: BWFPWS00 Mfr#: VCQK420-2G-PB
Power Efficient 3D Application Performance
The NVIDIA Quadro K420 delivers power-efficient 3D application performance and capability. 2GB of DDR3 GPU memory with fast bandwidth enables you to create complex 3D models, and a flexible single-slot and low-profile form factor makes it compatible with even the most space and power-constrained chassis. Plus, an all-new display engine drives up to four displays with DisplayPort 1.2 support for ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions— whether its product design, visualization and simulation, or spectacular visual storytelling—and get results to market faster.
3D Graphics Architecture
  • Scalable geometry architecture
  • Hardware tessellation engine
  • FXAA/TSAA dedicated antialiasing engine
  • Bindless Textures
  • Shader Model 5.0 (OpenGL 4.4 and DirectX 11)
  • Up to 16K x 16K texture and render processing
  • Transparent multisampling and super sampling
  • 16x angle independent anisotropic filtering
  • 32-bit per component floating point texture filtering and blending
  • Up to 64X full scene antialiasing (FSAA)
  • Decode acceleration for MPEG-2, MPEG-4 Part 2 Advanced Simple Profile, H.264, MVC, VC1, DivX (version 3.11 and later), and Flash (10.1 and later)
  • Dedicated H.264 encoder (requires application support)
  • Blu-ray dual-stream hardware accelerating (supporting HD picture-in-picture playback)
Parallel Computing Capabilities
  • SMX Architecture (streaming multi-processor design that delivers greater processing and efficiency)
  • Support for all the latest CUDA 6 features, including Unified Memory, Dynamic Parallelism and Dedicated Shared Memory)
  • Programming support for CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Python and Fortran
Advanced Display Features
  • Simultaneously drive up to two directly connected displays, each with the full capabilities of the display
  • Support up to four displays when using DisplayPort 1.2 multi-streaming
  • Dual DisplayPort 1.2 outputs including Multi-Stream and HBR2 support (capable of supporting resolutions such as 3840 x 2160)
  • DisplayPort 1.2 (up to 3840 x 2160 at 60Hz and 2560 x 1600 at 120Hz)
  • DVI-I Dual-Link output (up to 2560 x 1600 at 60Hz and 1920 x 1200 at 120Hz)
  • DVI-D Dual-Link output (up to 2560 x 1600 at 60Hz and 1920 x 1200 at 120Hz)
  • Internal 400MHz DAC DVI-I output (analog display up to 2048 x 1536 at 85Hz)
  • DisplayPort 1.2, HDMI 1.4, and HDCP support (HDMI requires 3rd party adapter)
  • Stereoscopic 3D display support including NVIDIA 3D Vision Pro and 3D Vision, 3D DLP, interleaved, and passive stereo
  • OpenGL and Direct3D quad buffered stereo support
  • Underscan/overscan compensation and hardware scaling
  • Support for NVIDIA Quadro Mosaic, NVIDIA NVIEW multi-display technology, NVIDIA Enterprise Management Tools
DisplayPort and HDMI Digital Audio
  • Dolby Digital (AC3), DTS 5.1, multi-channel (7.1) LPCM, Dolby Digital Plus (DD+), and MPEG-2/MPEG-4 AAC, DTS-HD, TrueHD
  • Data rates of 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176KHz, and 192KHz
  • Word sizes of 16-bit, 20-bit, and 24-bit
  • Enhanced compatibility
    Designed specifically for PC use, the NVIDIA Quadro K420 graphics card ensures seamless integration and performance stability across a wide range of desktop computing environments.
  • Impressive visuals
    With support for resolutions up to 3840 x 2160 at 60 Hz, the NVIDIA Quadro K420 delivers crisp, clear visuals on high-definition displays, making it ideal for professional design and multimedia tasks.
  • Robust memory capacity
    Equipped with up to 2 GB of installed video memory and a 128-bit bus width, this graphics card provides the bandwidth and capacity needed for complex 3D models and large data sets.
  • Advanced display technology
    Featuring NVIDIA Mosaic and Nvidia nVIEW Multi-Display Technology, the Quadro K420 supports extended desktops and cohesive workspaces, enhancing productivity and creative workflows.
NVIDIA Quadro K420 - graphics card - 2 GB
Graphics card
2 GB
Memory Interface
128-bit
Environmental Standards
ENERGY STAR Qualified
Graphics card
HDCP
Size
2 GB
Bus Width
128-bit
Min Hard Drive Space
200 MB
ENERGY STAR Certified
