PNY NVIDIA Quadro K1200 4GB PCI-E X16 4GB Graphics Card
Quicklinx: B9RWWS00 Mfr#: VCQK1200DVI-PB
NVIDIA Quadro K1200 - Incredible 3D application performance in a flexible form factor. Now included in the box, a full-height bracket lets this single-slot and low-profile board fit into any full-height (ATX) desktop, mid-tower, or desk side tower enclosure. Four mini-DisplayPort to DVI-D SL adapters are included to enable DVI or DisplayPort displays to be driven out of the box (four displays active simultaneously). The Quadro K1200 is the perfect choice for Manufacturing or Media & Entertainment professionals who are transitioning to 4K applications, workflows, and photorealistic HDR (High Dynamic Range) rendering enabled by NVIDIA Iray. 512 CUDA cores and 4 GB of GDDR5 GPU memory with fast bandwidth enables your customers to create large, complex 3D models, and an all-new display engine drives up to four displays natively with DisplayPort 1.2 support for true 4K resolutions like 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 100+ professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster. PNY provides unsurpassed service and commitment to its professional graphics customers offering: pre and post-sales support, dedicated Quadro Field Application engineers and direct tech support hot lines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, software installation disc and documentation to ensure a quick and successful install.
  • Energy efficient
    With ENERGY STAR certification, this graphics card ensures optimal energy efficiency, reducing power consumption and lowering energy costs while maintaining performance.
  • High-quality visuals
    Equipped with a 128-bit GDDR5 SDRAM and supporting up to 4 monitors, the NVIDIA Quadro K1200 for DVI delivers stunning, high-resolution visuals across multiple displays, perfect for multitasking and professional applications.
  • Advanced connectivity
    Featuring 4 Mini DisplayPort outputs with adapters for DisplayPort and DVI-D (Single-Link), this graphics card offers versatile connectivity options for a wide range of devices and display configurations.
  • Robust performance
    With 512 CUDA cores and support for DirectCompute, DirectX 12, OpenCL, and OpenGL 4.5, the NVIDIA Quadro K1200 is designed to handle demanding applications and graphics-intensive tasks with ease.
  • Enhanced features
    This graphics card boasts a suite of advanced features, including hardware video decode acceleration, NVIDIA GPU Boost, and Nvidia CUDA technology, ensuring smooth and efficient performance in professional environments.
NVIDIA Quadro K1200 for DVI - graphics card - Quadro K1200 - 4 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
4 GB GDDR5
CUDA Cores
512
Memory Interface
128-bit
Max Resolution
3840 x 2160
Max Monitors Supported
4
4 x Mini DisplayPort , 4 x DisplayPort - with adapter , 4 x DVI-D (Single-Link) - with adapter
API Supported
OpenCL, DirectCompute, DirectX 12, OpenGL 4.5
16 cm x 6.86 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA Quadro K1200
CUDA Cores
512
Max Resolution
4
API Supported
Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Dolby True HD support, DTS-HD Master Audio support, Hardware Video Decode Acceleration, Shader Model 5.0, Dolby Digital Plus, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, OpenGL Quad Buffered Stereo Support, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), ultra-quiet active fansink, HDCP
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
SunSoft Solaris, Linux, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8 / 8.1
Min RAM Size
2 GB
Min Hard Drive Space
200 MB
Additional Requirements
DVD-ROM
45 Watt
Full-height bracket
4 x Mini DisplayPort-DisplayPort adapter , 4 x Mini DisplayPort-DVI adapter
Software Included
Drivers & Utilities
16 cm
6.86 cm
ENERGY STAR Certified
Limited warranty - 3 years
