NVIDIA GRID technology offers the ability to offload graphics processing from the CPU to the GPU in virtualized environments, allowing the data center manager to deliver true PC graphics-rich experiences to more users for the first time. NVIDIA's Kepler-based GRID K2 board is specifically designed to enable rich graphics in virtualized environments.
GPU virtualization
GRID board features the NVIDIA Kepler architecture that, for the first time, allows hardware virtualization of the GPU. This means multiple users can share a single GPU, improving user density while providing true PC performance and compatibility. -
Low-latency remote display
NVIDIA's patented low-latency remote display technology greatly improves the user experience by reducing the lag that users feel when interacting with their virtual machine. With this technology, the virtual desktop screen is pushed directly to the remoting protocol. -
H.264 encoding
The Kepler GPU includes a high-performance H.264 encoding engine capable of encoding simultaneous streams with superior quality. This provides a giant leap forward in cloud server efficiency by offloading the CPU from encoding functions and allowing the encode function to scale with the number of GPUs in a server. -
Maximum user density
NVIDIA GRID board has an optimized multi-GPU design that helps to maximize user density. GRID K2 board, which includes two higher end Kepler GPUs, delivers maximum density for users of graphics-intensive applications. -
Power efficiency
GRID GPU is designed to provide data center-class power efficiency, including the streaming multiprocessor, called "SMX". The result is a proven solution that delivers performance per-watt for the enterprise data center. -
24/7 reliability
GRID board is designed, built, and tested by NVIDIA for 24/7 operation. Working closely with leading server vendors ensures GRID card perform optimally and reliably for the life of the system. -
Wide range of virtualization solutions
GRID board enables GPU-capable virtualization solutions, delivering the flexibility to choose from a wide range of proven solutions.
- NVIDIA Grid K2 MODULE (left to right) - graphics card - 2 GPUs - GRID K2 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- 2 GPUs - NVIDIA GRID K2
- Memory
- 8 GB GDDR5
- CUDA Cores
- 3072
- API Supported
- DirectX 11, OpenGL 4.3
- Fanless
- 26.5 cm x 11 cm
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Package Type
- Retail
- 3-year warranty
- Graphics card - fanless
- Bus Type
- Graphics Engine
- CUDA Cores
- 3072
- API Supported
- Dual Slot Fan Cooler, Kepler GPU Architecture, GPU Virtualization
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- 225 Watt
- 26.5 cm
- 11 cm
- Package Type
- Retail
- Limited warranty - 3 years
