PNY NVIDIA Kepler  16GB DDR3 PCI-E Grid K1 Module
Quicklinx: 9H12WS00 Mfr#: VCGRIDK1M-PB
GRID boards by PNY feature NVIDIA Kepler-based GPUs that, for the first time, allow hardware virtualization of the GPU. This means multiple users can share a single GPU, improving user density while providing true PC performance and compatibility.
The NVIDIA GRID K1 is a dual-slot 10.5-inch PCI Express generation 3 graphics board with four NVIDIA Kepler graphics processing units (GPUs). The NVIDIA GRID K1 has DDR3 memory, and a 130 W maximum power limit. The NVIDIA GRID K1 graphics board uses a passive heat sink that requires system airflow to properly operate the card within thermal limits. It is designed to accelerate graphics in virtual desktop environments, making it the ideal graphics processor for Microsoft RemoteFX and VMware vSGA.
NVIDIA Grid K1 MODULE - graphics card - 4 GPUs - GRID K1 - 16 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GPUs - NVIDIA GRID K1
16 GB DDR3
CUDA Cores
768
Fanless
26.5 cm x 11 cm
Package Type
Retail
3-year warranty
Graphics card - fanless
Bus Type
PCI Express 3.0 x16
Graphics Engine
CUDA Cores
768
Dual Slot Fan Cooler, Kepler GPU Architecture
Size
16 GB
DDR3 SDRAM
Additional Requirements
6 pin PCI Express power connector
130 Watt
26.5 cm
11 cm
Package Type
Retail
Limited warranty - 3 years
