GRID boards by PNY feature NVIDIA Kepler-based GPUs that, for the first time, allow hardware virtualization of the GPU. This means multiple users can share a single GPU, improving user density while providing true PC performance and compatibility.
The NVIDIA GRID K1 is a dual-slot 10.5-inch PCI Express generation 3 graphics board with four NVIDIA Kepler graphics processing units (GPUs). The NVIDIA GRID K1 has DDR3 memory, and a 130 W maximum power limit. The NVIDIA GRID K1 graphics board uses a passive heat sink that requires system airflow to properly operate the card within thermal limits. It is designed to accelerate graphics in virtual desktop environments, making it the ideal graphics processor for Microsoft RemoteFX and VMware vSGA.
- NVIDIA Grid K1 MODULE - graphics card - 4 GPUs - GRID K1 - 16 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- 4 GPUs - NVIDIA GRID K1
- Memory
- 16 GB DDR3
- CUDA Cores
- 768
- Fanless
- 26.5 cm x 11 cm
- Package Type
- Retail
- 3-year warranty
- Graphics card - fanless
- Bus Type
- Graphics Engine
- CUDA Cores
- 768
- Dual Slot Fan Cooler, Kepler GPU Architecture
- Size
- 16 GB
- Technology
- DDR3 SDRAM
- Additional Requirements
- 6 pin PCI Express power connector
- 130 Watt
- 26.5 cm
- 11 cm
- Package Type
- Retail
- Limited warranty - 3 years
