PNY GeForce GTX 650 1058MHz 1GB PCI-Express 3.0 HDMI
Quicklinx: 89LVWS00 Mfr#: GF650GTX1GEPB
  • High-Definition Multimedia Interface (HDMI)
  • NVIDIA® Kepler™ GPU architecture
  • Microsoft® DirectX® 11
  • NVIDIA TXAA and FXAA technologies
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA 3D Vision®-ready
  • NVIDIA PhysX® technology
  • NVIDIA Surround® technology
  • Support for three concurrent displays including : Two dual-link DVI, Mini-HDMI
  • NVIDIA CUDA® technology
  • PCI Express 3.0 support
  • OpenGL 4.2 support
Performances Features
  • Outputs : Dual DVI, Mini-HDMI
  • CUDA Cores : 384
  • Memory Capacity : 1 GB GDDR5
  • Memory Interface : 128-bit
  • Core Clock : 1058 MHz
  • Memory Speed : 5 GBPs
  • Memory Bandwith : 80 GB/sec
  • FIlRate : TBC billion texels/seconds
Minimum System Requirements
  • PCI Express-compliant motherboard with one dual-width x16 graphics slot
  • One 6-pin PCI Express supplementary power connector
  • Minimum 400W or greater system power supply (with a minimum 12V current rating of 20A)
  • 300 MB of available hard-disk space
  • 2GB system memory (4GB or higher recommended)
  • Microsoft Windows 7, Windows Vista, or Windows XP Operating System (32 or 64-bit)
  • DVD-ROM drive or Internet connection
Packaging Contents
  • PNY GeForce GTX 650 graphics card
  • Driver CD
  • Quick Install Guide
  • Y PCIE Power Connectors
  • 3 Years Manufacturer Warranty
  • Kepler GPU architecture
    NVIDIA's Kepler GPU architecture has been designed from the ground up not just for maximum performance in the latest DirectX 11 games, but optimal performance per watt. The SMX streaming multiprocessor is twice as efficient as the prior generation and the geometry engine draws triangles twice as fast. The result is world class performance and the highest image quality in an elegant and power efficient graphics card.
  • NVIDIA adaptive vertical sync
    Nothing is more distracting than framerate stuttering and screen tearing. The first tends to occur when framerates are low, the second when framerates are high. Adaptive V-sync is a smarter way to render frames. At high framerates, V-sync is enabled to eliminate tearing, at low frame rates, it's disabled to minimize stuttering. It gets rid of distractions so you can get on with gaming.
  • NVIDIA surround with up to four monitors
    Nothing is as breathtaking as playing your favorite games across three monitors. At 5760 x 1080, the expanded field of view fully engages human peripheral vision and provides for the most immersive experience in racing and flight simulators. Add in a fourth display to keep tabs on chat, email or web while you are gaming.
  • TXAA anti-aliasing
    Anti-aliasing helps to smooth out jagged lines in games. Existing techniques like MSAA are effective at removing jagged lines in still images but struggle with crawling and shimmering artifacts when the player is in motion. TXAA is a antialiasing mode that combines MSAA, temporal filtering, and post processing for the highest edge quality and minimal shimmering during gameplay.
  • NVIDIA 3D Vision ready
    NVIDIA 3D Vision brings a fully immersive, stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology.
  • NVIDIA PhysX technology
    Full support for NVIDIA PhysX technology, enabling a totally class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
PNY XLR8 GeForce GTX 650 - graphics card - GF GTX 650 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 650
1 GB GDDR5
Core Clock
1058 MHz
CUDA Cores
384
Memory Interface
128-bit
Max Monitors Supported
3
2 x DVI , Mini-HDMI
API Supported
DirectX 11, OpenGL 4.2
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1058 MHz
CUDA Cores
384
3
2 x DVI , Mini-HDMI
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture
Size
1 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
80 GBps
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Min RAM Size
2 GB
Min Hard Drive Space
300 MB
Required Power Supply
400 W
Additional Requirements
DVD-ROM, 6 pin PCI Express power connector
6 pin PCIe power cable
Software Included
Drivers & Utilities
Limited warranty - 3 years
Resources
The following resources are available for the PNY GeForce GTX 650 1058MHz 1GB PCI-Express 3.0 HDMI
