The GeForce® GTX 1080 Ti is NVIDIA’s new flagship gaming GPU, based on the NVIDIA Pascal™ architecture. The latest addition to the ultimate gaming platform, this card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive 11 GB frame buffer. #GameReady.
Ultimate GeForce
Performance?
The GeForce® GTX 1080 Ti is the world’s fastest gaming GPU. 3584 NVIDIA® CUDA® cores and a massive 11 GB frame buffer deliver 35% faster performance than the GeForce® GTX 1080.
NVIDIA Pascal? GeForce® GTX 10-Series graphics cards are powered by Pascal to deliver up to 3X the performance of previous-generation graphics cards, plus breakthrough gaming technologies and VR experiences.
VR Ready?
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
Innovative Design
Unprecedented gaming horsepower. Exceptional craftsmanship. A 7-phase dualFET power supply. All cooled by a radial fan with an advanced vapor chamber designed to for consistent performance in even the most thermally challenging environments. This is the forward-thinking innovation that makes the GeForce® GTX 1080 Ti the Ultimate GeForce.
Warranty
PNY stands behind our products, our GeForce® GTX 1080 Ti Founders Edition graphics cards are backed by a 3-Year warranty.
Ultimate GeForce
The GeForce GTX 1080 Ti is NVIDIA's flagship gaming GPU, based on the NVIDIA Pascal architecture. This card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive frame buffer. -
Amazing performance
The GeForce GTX 1080 Ti delivers faster performance than the GeForce GTX 1080. -
NVIDIA Pascal
GeForce GTX 10-Series graphics cards are powered by Pascal to deliver up to 3X the performance of previous-generation graphics cards, plus breakthrough gaming technologies and VR experiences. -
VR Ready
Discover next-generation VR performance, low latency, and Plug-and-Play compatibility - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment. -
Innovative design
- PNY GeForce GTX 1080 Ti - Founders Edition - graphics card - GF GTX 1080 Ti - 11 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080 Ti
- Memory
- 11 GB GDDR5X
- Core Clock
- 1480 MHz
- Boost Clock
- 1582 MHz
- CUDA Cores
- 3584
- Memory Interface
- 352-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1480 MHz
- Boost Clock
- 1582 MHz
- CUDA Cores
- 3584
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- API Supported
- Nvidia CUDA technology, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, Nvidia SLI with HB Bridge Support, NVIDIA Pascal GPU technology, Nvidia VR Ready, HDCP
- Size
- 11 GB
- Technology
- GDDR5X SDRAM
- Bus Width
- 352-bit
- OS Required
- Linux, FreeBSD (32-bit), Microsoft Windows 7 / 8 / 8.1 / 10
- Required Power Supply
- 600 W
- Additional Requirements
- 6-pin + 8-pin PCI Express power connectors
- 250 Watt
- Limited warranty - 3 years
