PNY GeForce GTX 1070 8GB XLR8 OC GAMING
Quicklinx: CDXCWS00 Mfr#: KF1070GTXXG8GEPB
Take on today's challenging, graphics-intensive games without missing a beat. The GeForce GTX 1070 graphics card delivers the incredible speed and power of NVIDIA Pascal - the most advanced GPU ever created - for truly revolutionary gaming and VR performance.
The GeForce GTX 1070 comes with ultra-fast FinFET technology and supports DirectX 12 features. This means you can count on an amazing experience in every application - including performance in AAA and immersive VR Ready games that's up to 3X faster than with previous-generation GPUs.
Get the power to drive next-generation displays, including VR, ultra-high-resolution, and multiple monitors. And bring more realism to every game with NVIDIA GameWorks technologies that offer a true cinematic experience and amazing new image-capture to share your game. All with the lowest latency and plug-and-play compatibility with leading VR headsets.
PNY GeForce GTX 1070 - XLR8 OC GAMING Edition - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1607 MHz
Boost Clock
1797 MHz
CUDA Cores
1920
Memory Interface
256-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
4 cm x 30 cm x 11 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1797 MHz
CUDA Cores
1920
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
Interfaces Details
API Supported
Nvidia CUDA technology, Triple Fan, NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, Nvidia SLI with HB Bridge Support, HDCP
Size
8 GB
GDDR5 SDRAM
Bus Width
256-bit
Linux, FreeBSD (32-bit), Microsoft Windows 7 / 8 / 8.1 / 10
Required Power Supply
550 W
Additional Requirements
Internet connection, 8 pin PCI Express power connector
160 Watt
RoHS, REACH
4 cm
30 cm
11 cm
Limited warranty - 3 years
CDXC C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.38
CDXC C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £11.25
CDXC C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £14.05
