PNY GeForce GTX 1060 3GB GDDR5 PCIe 3.0 x16 DVI HDMI DisplayPort
Quicklinx: CDX9WS00 Mfr#: GF1060GTX3GEPB
The PNY GeForce GTX 1060 graphics card is loaded with innovative gaming technologies, making it the perfect choice for the high-definition games. Powered by NVIDIA Pascal - the advanced GPU architecture - the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. This advanced graphics card is created with ultra-fast FinFET technology and supports DirectX 12 features to deliver fast, smooth, power-efficient gaming experiences.
PNY GeForce GTX 1060 - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
3 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1152
Memory Interface
192-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5, Vulkan
4.2 cm x 25.4 cm x 12.7 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1152
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
Interfaces Details
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, NVIDIA Ansel, HDCP
Size
3 GB
GDDR5 SDRAM
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
4.2 cm
25.4 cm
12.7 cm
Limited warranty - 3 years
CDX9 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.43
CDX9 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.34
CDX9 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.68
