Graphics processing has become an essential ingredient to the modern PC. Nowadays, PNY simply demand more from the PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows 7 Experience, the NVIDIA GeForce 210 graphics card brings impressive graphics processing power to your PC at an incredible value.
NVIDIA unified architecture
Fully unified graphics core dynamically allocates work to geometry, vertex, physics, or pixel shading operations, delivering superior graphics processing power. -
NVIDIA CUDA parallel computing architecture
CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks - such as video transcoding - delivering incredible performance improvements over traditional CPUs. -
DirectCompute support
It is full support for DirectCompute, Microsoft's GPU computing API. -
OpenCL support
It is full support for OpenCL GPU computing API. -
NVIDIA GeForce Unified Driver Architecture (UDA)
It delivers a proven record of compatibility, reliability, and stability with the widest range of games and applications. GeForce drivers provide the best out-of-box experience for every user and deliver continuous performance and feature updates over the life of GeForce GPUs. -
GigaThread technology
Massively multi-threaded architecture supports thousands of independent, simultaneous threads, providing extreme processing efficiency in advanced, next generation shader programs. -
NVIDIA Lumenex engine
Delivers stunning image quality and floating point accuracy at ultra-fast frame rates. -
16x Anti-aliasing technology
Lightning fast, high-quality anti-aliasing at up to 16x sample rates obliterates jagged edges. -
128-bit floating point High Dynamic-Range (HDR) lighting
It is twice the precision of prior generations for incredibly realistic lighting effects - now with support for anti-aliasing. -
NVIDIA PureVideo HD technology
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
Hardware decode acceleration
It provides ultra-smooth playback of H.264, VC-1, WMV, DivX, MPEG-2 and MPEG-4 HD and SD movies without the need for a dual or quad-core CPU. -
Dual-stream hardware acceleration
It supports picture-in-picture content for the ultimate interactive Blu-ray and HD DVD movie experience. -
Dynamic contrast enhancement and color stretch
Provides post-processing and optimization of High Definition movies on a scene by scene basis for spectacular picture clarity. -
Enhanced error resilience
Correct errors or losses in broadcast content to ensure crisp, high quality playback. -
Advanced spatial-temporal de-interlacing
It sharpens HD and standard definition interlaced content on progressive displays, delivering a crisp, clear picture that rivals high-end home-theater systems. -
High-quality scaling
It enlarges lower resolution movies and videos to HDTV resolutions, while maintaining a clear, clean image. Also provides downscaling of videos, including high-definition, while preserving image detail. -
Inverse telecine (3:2 and 2:2 pulldown correction)
It recovers original film images from films-converted-to-video (DVDs, 1080i HD content), providing more accurate movie playback and superior picture quality. -
Bad edit correction
When videos are edited, the edits can disrupt the normal 3:2 or 2:2 pulldown cadences. PureVideo uses advanced processing techniques to detect poor edits, recover the original content, and display perfect picture detail frame after frame for smooth, natural looking video. -
Noise reduction
It improves movie image quality by removing unwanted artifacts. -
Edge enhancement
It sharpens movie images by providing higher contrast around lines and objects. -
Dual-link HDCP capable
It is designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays. -
Dual-link DVI support
It is able to drive industry's largest and highest resolution flat-panel displays up to 2560 x 1600 and with support for High-bandwidth Digital Content Protection (HDCP). -
PCI Express 2.0 support
Designed for the PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
Full Microsoft DirectX 10.1 support
DirectX 10.1 GPU with full Shader Model 4.1 support delivers unparalleled levels of graphics realism and film-quality effects. -
OpenGL 3.1 optimization and support
It provides top-notch compatibility and performance for OpenGL applications.
- PNY GeForce 210 - graphics card - GF 210 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce 210
- Memory
- 1 GB DDR3
- Core Clock
- 589 MHz
- CUDA Cores
- 16
- Effective Memory Clock
- 1 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 2
- DVI-I (dual link) , HDMI , VGA
- API Supported
- OpenCL, DirectCompute, DirectX 10.1, OpenGL 3.3
- 14.5 cm x 6.9 cm
- 3-year warranty
- Bus Type
- Graphics Engine
- Core Clock
- 589 MHz
- CUDA Cores
- 16
- Max Resolution
- 4096 x 2160
- 2
- API Supported
- Nvidia CUDA technology, Nvidia PureVideo HD technology, Shader Model 4.1, Nvidia Unified GPU Architecture, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1 GHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- 30 Watt
- 14.5 cm
- 6.9 cm
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £28.49 |
