PMVmounts Mounting kit for LCD/plasma panel - 37"-60"
Quicklinx: FDLWWS00 Mfr#: PMVMOUNT3760DA
20 in stock
£184.06 ex VAT
£220.87 inc VAT
Marketing description is not available.
PMV Mounts PMVMOUNT3760DA - mounting kit
Mounting kit - wall-mountable
Mounting Components
Mounting plate, dual articulating arm, 2 interface brackets
Adjustable Depth
13-70 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
37"-60"
VESA Mounting Interface
200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Mounting Pattern Size
680 x 475 mm
Max Load Weight
75 kg
Adjustable Depth
13-70 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
680 x 475 mm
37"-60"
Adjustments
Tilt
Max Load Weight
75 kg
Swivel adjustment
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FDLW 041774
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £25.82
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: PMVmounts
Stock Status: In stock
Stock Status: Used Stock
