- PMV Mounts PMVMOUNT3760DA mounting kit - for flat panel
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Mounting plate, dual articulating arm, 2 interface brackets
- Adjustable Depth
- 13-70 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 37"-60"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Mounting Pattern Size
- 680 x 475 mm
- Max Load Weight
- 75 kg
- Adjustable Depth
- 13-70 cm
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 680 x 475 mm
- 37"-60"
- Adjustments
- Tilt
- Max Load Weight
- 75 kg
- Swivel adjustment
