PMV Mounts PMVMOUNT2036T - Wall mount for LCD / plasma panel - black satin powder coat - screen size: 32"-65"
- PMV Mounts PMVMOUNT2036T mounting kit - for flat panel - black satin powder coat
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 69 cm 42.7 cm
- Tilt
- -7.5° to 7.5°
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-65"
- VESA Mounting Interface
- 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 400 mm
- Max Load Weight
- 75 kg
- Black satin powder coat
- 69 cm
- 42.7 cm
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 32"-65"
- Tilt
- -7.5° to 7.5°
- Max Load Weight
- 75 kg
