PMVmounts Generic TV Trolley / Floor Stand 32" - 55" Black and Silver
Quicklinx: 7W3DWS00 Mfr#: PMVTROLLEY
Type: Cart
£388.24 ex VAT
£465.88 inc VAT
Marketing description is not available.
PMV Mounts PMVTROLLEY cart - for flat panel
Cart
72 cm x 60 cm x 170 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
32"-55"
VESA Mounting Interface
200 x 200 mm, 400 x 400 mm, 300 x 300 mm, 400 x 600 mm
Max Mounting Pattern Size
800 x 400 mm
Max Load Weight
50 kg
72 cm
60 cm
170 cm
AV Furniture
Cart
Recommended Use
Flat panel
800 x 400 mm
32"-55"
Adjustments
Tilt
Max Load Weight
50 kg
Adjustable height, wheels
Type: Cart
Brand: PMVmounts
