- PMV Mounts PMVTROLLEY - cart
- Product Type
- Cart
- 72 cm x 60 cm x 170 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 32"-55"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 400 mm, 300 x 300 mm, 400 x 600 mm
- Max Mounting Pattern Size
- 800 x 400 mm
- Max Load Weight
- 50 kg
- 72 cm
- 60 cm
- 170 cm
AV Furniture
- Cart
- Recommended Use
- Flat panel
- 800 x 400 mm
- 32"-55"
- Adjustments
- Tilt
- Max Load Weight
- 50 kg
- Adjustable height, wheels
