PMVmounts Large Universal Tilting Wall Mount for 37" to 65" Displays
Quicklinx: B74BWS00 Mfr#: PMVMOUNT2036T
£62.24 ex VAT
£74.68 inc VAT
PMV Mounts PMVMOUNT2036T - Wall mount for LCD / plasma panel - black satin powder coat - screen size: 32"-65"
PMV Mounts PMVMOUNT2036T mounting kit - for flat panel - black satin powder coat
Mounting kit - wall-mountable
Mounting Components
Wall mount
69 cm 42.7 cm
Tilt
-7.5° to 7.5°
Recommended Use
Flat panel
Recommended Display Size
32"-65"
VESA Mounting Interface
400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 400 mm
Max Load Weight
75 kg
Black satin powder coat
69 cm
42.7 cm
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
32"-65"
Tilt
-7.5° to 7.5°
Max Load Weight
75 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B74B 046257
Condition: This item is new and unused. The packaging is damaged.
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £8.73
Ref: B74B 046258
Ref: B74B 046259
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: PMVmounts
Stock Status: Used Stock
