Plustek SmartOffice SC8016U
Quicklinx: BLH3WS00 Mfr#: 0243UK
The Plustek SmartOffice SC8016U is a departmental class A3 sized document scanner that features 80 ppm (160 ipm) scan speed, 100 sheet feeder and 8,000 page per day duty cycle. Industry standard TWAIN driver ensures compatibility with almost any document imaging application.
  • Performance - fast, large feeder, high daily duty cycle
    Featuring a scan speed of 80 pages per minute, 160 images per minute in duplex mode, a 100 sheet feeder and a daily duty cycle of 8,000 pages per day, the SmartOffice SC8016U is designed for applications requiring frequent scanning of large document batches.
  • Productivity - handles a wide range of paper and card with no sorting
    The SmartOffice SC8016U scans mixed batches of documents without the need for separating or sorting. Embossed cards, such as IDs or driver licenses, and any sized paper document up to A3 size and 200" long can simply be stacked in the 100 sheet feeder. The SmartOffice SC8016U's paper handling system coupled with Plustek's advanced image processing provides you with automatically sized and exported images or PDFs. SmartOffice SC8016U's A3 sized feeder easily handles documents from 2" x 2" to 11.69" x 200".
  • Easy-to-use
    Single-touch customizable button automates up to 9 frequent scanning jobs. The innovative automatic wake-up function turns the scanner on as soon as documents are placed in the feeder.
  • Intelligent Misfeed function
    The ultrasonic sensor detects double feeding of original documents during scanning. The ultrasonic function can be turned off when scanning document with labels, sticky notes, or taped receipts. This innovative design prevents double feeding and effectively scans documents of different weights or thickness. Thanks to double-feed prevention, optimum reliability is assured even when scanning high volumes of documents.
  • Compatible with most imaging applications
    Industry standard TWAIN and WIA drivers combined with TIF, JPG, PDF and Microsoft Office file formats ensure compatibility with thousands of scanning and imaging programs. ABBYY FineReader Sprint is included to easily create and manage searchable PDFs at the touch of a button. Built in image processing ensures the highest image quality, reduces rescans, increases OCR accuracy and now includes automatic color detect.
  • Responsible - saves energy
    The SmartOffice SC8016U is environmentally responsible and easy to use at the same time thanks to its ENERY STAR certification, low power LED illumination technology and power-saving function. The SmartOffice SN8016U also features auto wake up that enables users to simply place the paper in the scanner and wake up the scanner from sleep/stand-by mode.
Plustek SmartOffice SC8016U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
United Kingdom
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
305 mm x 5080 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
8000 scans per day
Microsoft Windows 2000/XP/Vista/7, Windows 8
43.6 cm x 26.2 cm x 26.6 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A3 (297 x 420 mm)
United Kingdom
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
8000 scans per day
Scanner Speed Details
80 ppm - landscape (front) / greyscale (back) - A4 - 300 dpi , 160 ipm - landscape (front) / greyscale (back) - A4 - 300 dpi , 80 ppm - landscape (front) / black & white (back) - A4 - 300 dpi , 160 ipm - landscape (front) / black & white (back) - A4 - 300 dpi , 45 ppm - landscape (front) / colour (back) - A4 - 200 dpi , 90 ipm - landscape (front) / colour (back) - A4 - 200 dpi , 30 ppm - landscape (front) / colour (back) - A4 - 300 dpi , 60 ipm - landscape (front) / colour (back) - A4 - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Blank Page Removal, automatic colour detection, Multi-Image Output, Auto Crop, Auto Deskew, Auto Document Rotation
TWAIN, ISIS
Media Handling
Max Document Size
305 mm x 5080 mm
Automatic
100 sheets
USB 2.0
ENERGY STAR Certified
External power adapter
Software Included
Plustek DocAction, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint, NewSoft Presto! PageManager 7.23, Plustek DI Express 6
System Requirements Details
Pentium 4 - 3.2 GHz - RAM 1 GB - HD 800 MB
43.6 cm
26.2 cm
26.6 cm
9 kg
