Brand
Plustek SmartOffice PS456U
Quicklinx: BLH2WS00 Mfr#: 0241UK
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 244 x 356 mm
Interface: USB 2.0
Compatibility: PC
£429.08 ex VAT
£514.89 inc VAT
The Plustek SmartOffice PS 456U is a 80-page per minute, duplex color document scanner that is not only fast, it's reliable and cost effective. Ultrasonic misfeed detection ensures all of your critical documents are imaged correctly. Robust paper handling, advanced image processing and a high daily duty cycle all add up to the perfect departmental scanning solution for document management, content management and forms processing applications.
  • Exceptional document handling
    The SmartOffice PS456U features one of the most advanced document feeding and separation system in the industry. This system allows the SmartOffice PS456U to scan mixed batches of varying paper sizes and weights. No more wasted time sorting documents based on their size or thickness. Plastic and rigid cards such as ID cards, drivers licenses, membership cards, insurance cards and even log documents up to 98" are scanned without additional adjustments or additional set up.
  • Exceptional productivity
    Create searchable PDFs at the touch of a button. Single touch scanning allows you to define 9 different scanning functions that can all be accessed by simply pressing a button. In addition to searchable PDF, you can transform your paper documents into editable Microsoft Office document formats or common image formats such as JPG and TIFF. Industry standard TWAIN, ISIS and WIA drivers ensure compatibility with thousands of image enabled applications.
  • Exceptional reliability
    The 100-sheet feed tray along with a daily duty cycle of 6000 pages means that the SmartOffice PS456U is a scanner that is designed to scan documents every day, all day long.
  • Intelligent misfeed function
    The ultrasonic sensor detects the double feeding of original documents during scanning. The ultrasonic function can be turned off when scanning document with labels, sticky notes, or taped receipts. This design prevents double feeding and effectively scans documents of different weights or thickness. Thanks to double-feed prevention, optimum reliability is assured even when scanning high volumes of documents.
  • Environmentally responsible and energy-saving
    The SmartOffice PS456U is environmentally responsible and easy to use at the same time thanks to its ENERY STAR certification, low power LED illumination technology and power-saving function. The SmartOffice PS456U also features auto wake up that enables users to simply place the paper in the scanner and wake up the scanner from sleep/stand-by mode.
Plustek SmartOffice PS456U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
244 x 356 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
244 mm x 2530 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
6000 scans per day
Microsoft Windows 2000/XP/Vista/7, Windows 8
31.87 cm x 23.07 cm x 22.83 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
244 x 356 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
30 ppm - portrait (front) / colour (back) - A4 - 300 dpi , 60 ipm - portrait (front) / colour (back) - A4 - 300 dpi , 45 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 90 ipm - portrait (front) / colour (back) - A4 - 200 dpi , 80 ppm - portrait (front) / greyscale (back) - A4 - 300 dpi , 160 ipm - portrait (front) / greyscale (back) - A4 - 300 dpi , 80 ppm - portrait (front) / black & white (back) - A4 - 300 dpi , 160 ipm - portrait (front) / black & white (back) - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
244 mm x 2530 mm
Automatic
100 sheets
USB 2.0
ENERGY STAR Certified
External power adapter
Software Included
Plustek DocAction, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint, Plustek DI Express 6
System Requirements Details
Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
31.87 cm
23.07 cm
22.83 cm
2.7 kg
Interface: USB 2.0
Compatibility: PC
Brand: Plustek
