Let's begin! You may find the SmartOffice PS406U is the right solution for your scanning needs. Enhanced with innovative features, it offers outstanding price/performance value in a compact footprint, conserving both space and budget. You get fast scanning speeds, a high daily duty cycle and robust paper handling capabilities, all from a compact, desktop scanner. You may feel this scanner delivers solutions for a multitude of imaging applications. Whatever you may involve such as document management, archiving, workflow or forms processing, watch this video of the SmartOffice PS406U that scans both sides of documents, in color in just a few seconds.
Features exceptional feeding reliability
The SmartOffice PS406U has the efficiency of Intelligent MultiFeed Function. The ultrasonic sensor of the scanner detects the double feeding of original documents during scanning. Also, the ultrasonic function can be turned off for the purpose of intentional double-feeds such as taped receipt or sticky notes. This innovative design prevents double feeding and effectively scans documents of different weights or thickness. Thanks to double-feed prevention, optimum reliability is assured even when scanning high volumes of documents. -
Save time with one-touch scan to Searchable PDF
The SmartOffice PS406U lets you transform paper into useful digital information cost effectively. It provides a simple user interface that requires no special training in order for you to become productive immediately. This departmental scanner conveniently includes everything in the box to get organizations up and scanning. With the Plustek DocAction, Plustek DI Capture, OCR and BCR software, users get image enhancement functionality as well as the option of scanning directly to Searchable PDF file, print or batch. Multi-page documents on both sides can be processed into electronic searchable PDF files at the touch of a button. -
Bring digital documents to your departments
The SmartOffice PS406U document scanner makes document warehousing a simple task, with high-speed scanning at the touch of a button. 40 pages per minute and 80 images per minute, newly customized high speed Twain drivers, a 100-page duplexing ADF make this the first choice for document processing. It supports most major scanning environments. Alongside its Plustek DocTwain driver, it offers users more flexibility and supports auto document sizing. This contributes to faster scanning speed and greater productivity, and can be used for batch scanning with the ADF. Without this function, it is necessary to spend time manually entering the paper size during their pre-scan. Thanks to auto document sizing, this time is now saved.
- Plustek SmartOffice PS406U - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Max Supported Document Size
- 244 x 356 mm
- Localisation
- United Kingdom
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 244 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 4000 scans per day
- System Requirements
- Microsoft Windows 2000/XP/Vista/7
- Microsoft Certification
- Compatible with Windows 7
- 31.9 cm x 23.1 cm x 22.8 cm
- 2.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 244 x 356 mm
- Localisation
- United Kingdom
Scanner
- Input Type
- 600 dpi x 600 dpi
- CCD
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Control Panel Buttons Functions
- Scan-to-PDF
- Duty Cycle
- Scanner Speed Details
- 40 ppm - portrait (front) / colour (back) - A4 - 200 dpi , 80 ipm - portrait (front) / colour (back) - A4 - 200 dpi , 40 ppm - portrait (front) / greyscale (back) - A4 - 300 dpi , 80 ipm - portrait (front) / greyscale (back) - A4 - 300 dpi , 40 ppm - portrait (front) / black & white (back) - A4 - 300 dpi , 80 ipm - portrait (front) / black & white (back) - A4 - 300 dpi
- Scanner Features
- Ultrasonic Double Feed Detection
- TWAIN
Media Handling
- Max Document Size
- 244 mm x 356 mm
- Automatic
- 100 sheets
- USB 2.0
- Included Accessories
- Automatic document feeder, calibration card
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Plustek DI Capture, Plustek DocAction, NewSoft Presto! PageManager 7.10, HotCard BizCard Finder 3.0, ABBYY FineReader 9.0 Sprint
- OS Required
- System Requirements Details
- Pentium 4 - 2 GHz - RAM 1 GB - HD 800 MB
- 31.9 cm
- 23.1 cm
- 22.8 cm
- 2.7 kg
